Author Topic: Looking for a faster version of delete_nth, insert_nth and switch_nth  (Read 3909 times)
terrycadd
I have recently been very interested in your threads of modifying lists.
I have three functions which I wrote a long while back that can be improved upon to improve the speed of execution. Until I read your recent threads I always felt “If it’s not broke don’t fix it.”  Here are the three functions I am referring to.
* A delete nth or remove nth function.
; Delete_nth - Deletes the nth item from a list.
; Arguments: 2
;   Num# = Nth number in list to delete
;   OldList@ = List to delete the nth item
; Returns: A list with the nth item deleted.
(defun Delete_nth (Num# OldList@ / Cnt# Item NewList@)
  (if (and (= (type Num#) 'int)(= (type OldList@) 'list))
      (setq Cnt# 0)
      (foreach Item OldList@
        (if (/= Cnt# Num#)
          (if NewList@
            (setq NewList@ (append NewList@ (list Item)))
            (setq NewList@ (list Item))
          );if
        );if
        (setq Cnt# (1+ Cnt#))
      );foreach
    );progn
    (setq NewList@ OldList@)
  );if
  NewList@
);defun Delete_nth
* A insert nth or add an nth function.
; Insert_nth - Inserts a new item value into the nth number in list.
; Arguments: 3
;   Num# = Nth number in list to insert item value
;   Value = Item value to insert
;   OldList@ = List to insert item value
; Returns: A list with the new item value inserted.
(defun Insert_nth (Num# Value OldList@ / Cnt# Item NewList@)
      (setq Cnt# 0)
        (if (= Cnt# Num#)
            (if NewList@
              (setq NewList@ (append NewList@ (list Value)))
              (setq NewList@ (list Value))
            );if
            (if NewList@
            );if
          );progn
          (if NewList@
          );if
        );if
      );foreach
      (if (>= Num# (length OldList@))
        (if NewList@
        );if
      );if
    );progn
  );if
  NewList@
);defun Insert_nth
* A switch nth or swap two nths function.
; Switch_nth - Switches the nth Num1# and Num2# item values in a list.
; Arguments: 3
;   Num1# = nth number in list to switch with nth Num2#
;   Num2# = nth number in list to switch with nth Num1#
;   OldList@ = List to switch item values
; Returns: A list with two item values switched.
(defun Switch_nth (Num1# Num2# OldList@ / Cnt# Item NewList@ NewValue Valid)
  (if (and (= (type Num1#) 'int)(= (type Num2#) 'int)(= (type OldList@) 'list))
    (setq Valid t)
  );if
  (if (and Valid (< Num1# (length OldList@))(< Num2# (length OldList@))
      (/= Num1# Num2#)
    );and
      (setq Cnt# 0)
          ((= Cnt# Num1#)(setq NewValue (nth Num2# OldList@)))
          ((= Cnt# Num2#)(setq NewValue (nth Num1# OldList@)))
          (t (setq NewValue Item))
        );cond
        (if NewList@
          (setq NewList@ (append NewList@ (list NewValue)))
          (setq NewList@ (list NewValue))
        );if
      );foreach
    );progn
  );if
  NewList@
);defun Switch_nth
P.S. Also where can I find the mentioned BenchMark function?
Re: Looking for a faster version of delete_nth, insert_nth and switch_nth
« Reply #1 on: January 02, 2007, 12:07:05 PM »
To get the Benchmark.lsp
« Reply #2 on: January 02, 2007, 12:37:16 PM »
Well for remove you could convert this one
;;  CAB 12/27/2006
;;  (RemoveNth 3 '(0 1 2 3 4 5))
;;  (0 1 2 4 5)
(defun removeNth (i lst)
  (setq i (1+ i))
  (vl-remove-if '(lambda(x) (zerop (setq i (1- i)))) lst)
To replace yours like this:
; Arguments: 2
;   lst = List to delete the nth item
(defun Delete_nth (i lst )
  (if (and (= (type i) 'int)
           (listp lst)
           (> (length lst) 0))
      (setq i (1+ i))
    lst
);defun Delete_nth
(defun c:test()
  (print (Delete_nth 0 '(0 1 2 3 4 5 6 7)))
  (print (Delete_nth 4 '(0 1 2 3 4 5 6 7)))
  (print (Delete_nth 7 '(0 1 2 3 4 5 6 7)))
  (print (Delete_nth -1 '(0 1 2 3 4 5 6 7)))
  (print (Delete_nth 2.0 '(0 1 2 3 4 5 6 7)))
  (print (Delete_nth -1 nil))
Command: test
(1 2 3 4 5 6 7)
(0 1 2 3 5 6 7)
(0 1 2 3 4 5 6)
(0 1 2 3 4 5 6 7)
(0 1 2 3 4 5 6 7)
nil
Note that is you are testing for a list with this (= (type lst) 'list) a nil for lst will return true
so you need to test length as well with this (> (length lst) 0)
« Reply #3 on: January 02, 2007, 01:08:15 PM »
For the swap you could use this.
Did not add you additional error check.
;;  CAB 01/02/2007
;;  Swap i1 to i2 & i2 to i1 in list
(defun SwapNth (i1 i2 lst / idx)
  (setq idx -1)
  (if (and (< -1 i1 (length lst)) (< -1 i2 (length lst)))
    (mapcar '(lambda (x)
               (setq idx (1+ idx))
                 ((= idx i2) (nth i1 lst))
                 ((= idx i1) (nth i2 lst))
                 (x)
      lst
    lst ; reSwap this line if you want nil returned if out of range
(defun c:test ()
  (print (SwapNth 3 1 '("a" "b" "c" "d" "e" "f")))
  (print (SwapNth 1 3 '("a" "b" "c" "d" "e" "f")))
  (print (SwapNth 0 4 '("a" "b" "c" "d" "e" "f")))
  (print (SwapNth 1 10 '("a" "b" "c" "d" "e" "f")))
  (print (SwapNth 10 1 '("a" "b" "c" "d" "e" "f")))
Command: test
("a" "d" "c" "b" "e" "f")
("e" "b" "c" "d" "a" "f")
terrycadd
« Reply #4 on: January 02, 2007, 03:37:51 PM »
CAB,
I just got through testing your RemoveNth and SwapNth functions in this thread and they are incredibly fast.
Thanks,
Terry
P.S. I still looking for an insert_nth function.
« Reply #6 on: January 02, 2007, 03:55:32 PM »
I think this will be the fastest routine. I lost track of where I got it though.
;; by Reni U.
;;; Insert atom in list at pos n
(defun insert (lst x n)
    ((zerop n) (cons x lst))
    (T (cons (car lst) (insert (cdr lst) x (1- n))))))
terrycadd
« Reply #7 on: January 03, 2007, 11:03:23 AM »
CAB,
Thanks for your leads and tips. Here are the two versions that worked the fastest.
Both functions were modified to accept only nth positions between 0 and 1+ the length of the original list.
Insertnth is based upon the last Insert@ example, and Insert-nth is based upon the Insert example.
(defun Insertnth (pos item lst / tmp)
  (if (< -1 pos (1+ (length lst)))
      (repeat pos
        (setq tmp (cons (car lst) tmp)
              lst (cdr lst)
        );setq
      );repeat
      (append (reverse tmp) (list item) lst)
    );progn
    lst
  );if
);defun
(defun Insert-nth (pos item lst)
      ((zerop pos) (cons pos lst))
      (t (cons (car lst)(Insert-nth (1- pos) item (cdr lst))))
    );cond
    lst
  );if
);defun
