Author Topic: (challenge) find numbers  (Read 7914 times)
« on: May 21, 2004, 05:12:58 PM »
I got, what i think could be a fun little challenge if your up to it.
Come up with a cool way to locate "numbers" in a string. -i.e. If i have the string:
"My pipe is 2'' in diameter." I want a procedure to tell me where (by a zero based index --the first charater is zero) that number is. So... using my example string, our procedure would have to return "11". Get it? After we come up with some cool procedures we can maybe time some and get the fastest ones ...have a race.
Sound fun? Sound hard? Sound to wimpy? Am i nuts?
OBTW, I just posted this over at The vault too. :D :P
« Reply #1 on: May 21, 2004, 05:15:04 PM »
Now who's double posting......... :D
« Reply #2 on: May 21, 2004, 05:16:14 PM »
- Challenge -
do we have to find _all_ the numbers or just the first one(s)?
« Reply #3 on: May 21, 2004, 05:22:35 PM »
Oh you bastard!...
Umm just the first one will do.
« Reply #4 on: May 21, 2004, 05:30:56 PM »
Damn! I just ran a test (without any pseudo code or anything --i know, i know) and i did it already!?  That was kinda wussy!
« Reply #5 on: May 21, 2004, 05:41:55 PM »
quick-n-dirty and needs some more work.
usage: (remove-num "this is a text 123.556 string")
(defun remove-num (str / lst)
  (setq lst (vl-string->list str))
  (vl-list->string
    (vl-remove-if
      '(lambda (z)
         (cond ((> z 58))
               ((< z 45))
               ((= z 47))
      lst
DParcon
« Reply #6 on: May 21, 2004, 07:29:40 PM »
Here's my lisp version:
(defun getnum (xstr)
  (if (= (type xstr) 'STR)
      (setq str ""
            flag nil
      (while (and (not (eq xstr "")) (setq item (substr xstr 1 1)))
          ((and flag (= item "."))
            (setq str (strcat str item)
                  xstr (substr xstr 2)
          ((numberp (read (substr xstr 1 1)))
             (if (not flag) (setq flag T))
          (T (if flag
               (setq xstr "")
               (setq xstr (substr xstr 2))
        );cond
      );while
    );progn
  );if
  str
);defun
« Reply #7 on: May 21, 2004, 08:08:37 PM »
Returns a  pointer or nil
(defun c:get_pointer ()
  (setq pointer
         (numindex "My pipe is 2\" in diameter.")))
((defun numindex (str / lst)
  (car (vl-remove nil
         (mapcar '(lambda (x) (vl-position x lst))
                 (vl-string->list "0123456789")))))
« Reply #8 on: May 21, 2004, 11:09:57 PM »
I think an article on writing specifications is due.
What is a "number" ? your quotes
How do you want these handled. ?
36 blind mice.
4 score and 7 years ago ...
11 + 201 = 212
The answer is 212.03
The answer is 212.03. 9 details are to follow.
« Reply #9 on: May 22, 2004, 01:38:01 AM »
This isn't terribly efficient, but it's a late Friday night after a long week and I did this merely for fun (AutoCAD 2000+) ...
(defun FindNumbers ( String / Distil NumList Result )
   (defun Distil ( lst )
      (while (eq 46 (car lst)) (setq lst (cdr lst)))
      (setq lst (reverse lst))
      (reverse lst)
   (foreach Code
      (reverse
         (mapcar
           '(lambda (Code)
               (if (or (< 47 Code 58) (eq 46 Code))
                  Code
                  32
            (vl-string->list String)
      (if (eq 32 Code)
         (if NumList
            (setq
               Result  (cons NumList Result)
               NumList nil
         (setq NumList (cons Code NumList))
   (mapcar 'vl-list->string
      (vl-remove-if 'null
         (mapcar 'Distil
            (if NumList
               Result
(defun c:Test ()
   (foreach string
         "36 blind mice."
         "4 score and 7 years ago ..."
         "11 + 201 = 212"
         "The answer is 212.03"
         "The answer is 212.03. 9 details are to follow"
      (princ (strcat "\n\"" string "\" -> "))
      (princ (FindNumbers string))
(c:Test)
"36 blind mice." -> (36)
"4 score and 7 years ago ..." -> (4 7)
"11 + 201 = 212" -> (11 201 212)
"The answer is 212.03" -> (212.03)
"The answer is 212.03. 9 details are to follow" -> (212.03 9)
I'll toss this challenge back to you: Find negative numbers (ascii code 45) too :)
Fuccaro
« Reply #10 on: May 22, 2004, 02:10:14 AM »
(defun find_nr(a / i index b)
  (setq i 0 index nil)
  (while (and (< i (strlen a)) (not index))
    (setq b (substr a (setq i (1+ i)) 1))
    (if (and (<= "0" b) (>= "9" b)) (setq index (1- i))))
usage: (find_nr "string to search")
« Reply #11 on: May 22, 2004, 08:17:23 AM »
I spose i should post my "test" that i ran and got results right away with huh? Ok its early Sat. morning and i tried to rebuild what i have at work so if its wrong, i dont care --im tired. :D
(defun test (str / cntr)
  (setq cntr 0)
  (mapcar
    '(lambda (x)
       (if (eq (and (> x 48) (< x 57)) 'T)
         (setq flag cntr)
         (setq cntr (1+ cntr))))
  flag)
Command: (test "Thi is a 3 test")
9
SMadsen
« Reply #12 on: May 22, 2004, 08:46:54 AM »
This will return position of each digit in a string
(defun digitPos (str / i)
  (setq i -1)
  (vl-remove 'nil (mapcar '(lambda (n)(setq i (1+ i))(if (numberp n) i))
     (mapcar 'read (mapcar 'chr (vl-string->list str)))))
(digitPos "she had 3 pigs and 34 cows")
(8 19 20)
« Reply #13 on: May 22, 2004, 09:30:50 AM »
Stig, late to the party but a grand entrance.. :)
Michael  you have taken it to the next logical level,
extracting the numbers that is.
Stig there was a thread some time back that dealt with
converting strings to numbers or maybe it was converting
user input to numbers. I remember it was dealing with numbers
like 13'6   20'10"  25'-8 1/2"  I can't seem to find it.
Do you remember the thread an how to find it?
Oh, thanks Se7en for the challenge.
« Reply #14 on: May 22, 2004, 09:54:44 AM »
I suppose I should have responded to the challenge, not my perception of what would be useful (that's a real bad habit of mine), so ... here's my lame attempt at a more appropriate response:
(defun FindNumbers ( string / lst i result )
   (repeat (setq i (length (setq lst (vl-string->list string))))
      (if (< 47 (nth (setq i (1- i)) lst) 58)
         (setq result (cons i result))
   result
Command: test
"36 blind mice." -> (0 1)
"4 score and 7 years ago ..." -> (0 12)
"11 + 201 = 212" -> (0 1 5 6 7 11 12 13)
"The answer is 212.03" -> (14 15 16 18 19)
"The answer is 212.03. 9 details are to follow" -> (14 15 16 18 19 22)
Cheers :)
