Author Topic: Replace nth member of a list  (Read 28066 times)
Re: Replace nth member of a list
« Reply #15 on: December 27, 2006, 07:31:53 PM »
try this
(RemoveNth 3 '(3 1 2 3 4 5))
« Reply #16 on: December 27, 2006, 07:42:04 PM »
great thread guys ..
It's Alive!
  • Retired
  • AKA Daniel
« Reply #17 on: December 27, 2006, 07:46:09 PM »
try this
hmm not good
(1 2 4 5)
It's Alive!
  • Retired
  • AKA Daniel
« Reply #18 on: December 27, 2006, 08:27:31 PM »
ok I think this is a little better
;;(replace "a" 3 '(0 1 2 3 4 5 6))
(defun replace (a n lst / e i nl)
 (setq nl '()
       i 0
 (foreach e lst
  (if (= i n)
   (setq nl (cons a nl))
   (setq nl (cons e nl))
  (setq i (1+ i))
 (reverse nl)
and
;;(RemoveNth 3 '(3 0 1 2 3 4 5))
(defun removeNth (n lst / e i nl)
 (setq nl '()
       i 0
 (foreach e lst
  (if (/= i n)
  (setq i (1+ i))
 (reverse nl)
« Last Edit: December 27, 2006, 08:29:16 PM by Danielm103 »
« Reply #19 on: December 27, 2006, 09:26:45 PM »
Terry,
How about this?
;;  CAB 12/27/06
;;  move i1 to i2 in list
;; Does not catch i1 or i2 <0 or > (length lst)
(defun MoveNth (i1 i2 lst / idx)
  (setq idx -1)
  (mapcar '(lambda (x)
             (setq idx (1+ idx))
                 ((= idx i2) (nth i1 lst))
                 ((and (> i1 i2) (or (< idx i2)(> idx i1))) x)
                 ((and (> i2 i1) (>= idx i2)) x)
                 ((and (> i2 i1) (>= idx i1)) (nth (1+ idx) lst))
                 ((> idx i2) (nth (1- idx) lst))
               (x)
          lst
PS Does not catch index out of range, i1 or i2 < 0 or > (length lst)
« Last Edit: December 28, 2006, 11:27:34 AM by CAB »
terrycadd
« Reply #20 on: December 28, 2006, 12:09:28 AM »
Sweet! You reduced it to less than a third. Great code. Here is another one that I use for removing a bunch of items at a time. It’s not as lengthy as move_nth, but can be improved upon.
; Remove_nths - Removes the RemoveList@ of nths from a list.
; Arguments: 2
;   RemoveList@ = List of nths to remove
;   OldList@ = List to remove the list of nths from
; Returns: A list with the list of nths removed.
(defun Remove_nths (RemoveList@ OldList@ / Cnt# Item NewList@)
  (setq Cnt# 0)
  (foreach Item OldList@
    (if (not (member Cnt# RemoveList@))
      (setq NewList@ (append NewList@ (list Item)))
    );if
    (setq Cnt# (1+ Cnt#))
  );foreach
  NewList@
);defun Remove_nths
« Last Edit: December 28, 2006, 12:13:42 AM by Terry Cadd »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #21 on: December 28, 2006, 04:01:03 AM »
(defun Remove_nths (lst1 lst2)
  (if (and lst1 lst2)
    (if (zerop (car lst1))
      (Remove_nths (mapcar '1- (cdr lst1)) (cdr lst2))
      (cons (car lst2) (Remove_nths (mapcar '1- lst1) (cdr lst2)))
    ) ;_ if
    lst2
  ) ;_ if
) ;_ defun
Test:
(setq lst1 (vl-sort '(4 20 0) '<)  lst2 '("a" "b" "c" "d" "e" "f"))
(Remove_nths lst1 lst2)
'("b" "c" "d" "f")
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #22 on: December 28, 2006, 05:23:36 AM »
(defun MoveNth (i1 i2 lst / MoveNth_1)
  (defun MoveNth_1 (i1 i2 lst x i)
      ((or (and (> i i1) (> i i2)) (= i1 i2)) lst)
      ((= i i1) (MoveNth_1 i1 (1+ i2) (cdr lst) x (1+ i)))
      ((= i i2) (cons x (MoveNth_1 (1+ i1) i2 lst x (1+ i))))
      ((cons (car lst) (MoveNth_1 i1 i2 (cdr lst) x (1+ i))))
    ) ;_ cond
  ) ;_ defun
  (MoveNth_1 i1 i2 lst (nth i1 lst) 0)
) ;_ defun
Test:
(MoveNth 3 1  '("a" "b" "c" "d" "e" "f"));=> '("a" "d" "b" "c" "e" "f")
(MoveNth 1 3  '("a" "b" "c" "d" "e" "f"));=> '("a" "c" "d" "b" "e" "f")
(MoveNth 1 10 '("a" "b" "c" "d" "e" "f"));=> '("a" "c" "d" "e" "f" nil nil nil nil nil "b")
(MoveNth 10 1 '("a" "b" "c" "d" "e" "f"));=> '("a" nil "b" "c" "d" "e" "f" nil nil nil nil)
« Reply #23 on: December 28, 2006, 05:31:40 AM »
nice lesson Evgeniy   !!
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #24 on: December 28, 2006, 06:02:00 AM »
Thanks!  :-)
Other variant...
  (defun MoveNth_1 (i1 i2 lst x)
      ((or (and (minusp i1) (minusp i2)) (= i1 i2)) lst)
      ((zerop i1) (MoveNth_1 (1- i1) i2 (cdr lst) x))
      ((zerop i2) (cons x (MoveNth_1 i1 (1- i2) lst x)))
      ((cons (car lst) (MoveNth_1 (1- i1) (1- i2) (cdr lst) x)))
    ) ;_ cond
  ) ;_ defun
  (MoveNth_1 i1 i2 lst (nth i1 lst))
) ;_ defun
terrycadd
Topic of nths of lists
« Reply #25 on: December 28, 2006, 10:55:53 AM »
The versions of moventh presented so far return the same results if the arguments for the nths are possible in the list. My version returns the original list if the arguments for the nths are not possible. I’m not comfortable with adding nils in a list where you might be expecting some other type of data. That means you would have to always have to double check if the value you need is a real value.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #26 on: December 28, 2006, 11:04:35 AM »
No problem...
      ((and (> i i1) (> i i2)) lst)
    ) ;_ cond
  ) ;_ defun
  (if (and (/= i1 i2) (<= 0 i1 (length lst)) (<= 0 i2 (length lst)))
    lst
  ) ;_ if
) ;_ defun
<edit: modified code>
« Last Edit: December 28, 2006, 12:00:34 PM by ElpanovEvgeniy »
« Reply #27 on: December 28, 2006, 11:13:45 AM »
As Evgeniy said, "No Problem" :)
;;  CAB 12/28/06
  (setq idx -1)
  (if (and (< -1 i1 (length lst)) (< -1 i2 (length lst)))
               (setq idx (1+ idx))
                 (x)
      lst
    lst ; remove this line if you want nil returned if out of range
(defun c:test ()
  (print (MoveNth 3 1 '("a" "b" "c" "d" "e" "f")))
  (print (MoveNth 1 3 '("a" "b" "c" "d" "e" "f")))
  (print (MoveNth 1 10 '("a" "b" "c" "d" "e" "f")))
  (print (MoveNth 10 1 '("a" "b" "c" "d" "e" "f")))
« Last Edit: December 28, 2006, 11:25:30 AM by CAB »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #28 on: December 28, 2006, 11:16:57 AM »
 :-D  :-D  :-D
terrycadd
« Reply #29 on: December 28, 2006, 02:20:08 PM »
You guys are the greatest. This is a fun thread.
The checks in the mail. (ha!)
