Author Topic: Replace nth member of a list  (Read 28036 times)
« on: December 27, 2006, 10:24:32 AM »
Ok, I am having a serious brain fart this morning .. maybe because I have had too much egg nog or tequila .. your choice ... anyway, I need a clean and effective method to replace the nth member of a list. Example:
(setq newlist (replace index oldlist newitem))
If I had a dotted pair I could use a simple subst, but unfortunately I don't have one and it would likely be a nightmare since it would be possible to have 2 identical pairs in the list.
Re: Replace nth member of a list
« Reply #1 on: December 27, 2006, 10:33:43 AM »
Here is my shot at it.
(defun c:test ()
  (setq lst '(0 1 2 3 4 5 6))
  (setq new (swapnth lst 3 "A"))
;; CAB 11/15/2006
;;  replace nth item in list
(defun swapnth (lst i1 itm / tmp nlst)
  (while (and (> i1 0)
              (< (length (setq nlst (cons (car lst) nlst))) i1))
    (setq lst (cdr lst))
  (setq nlst (cons itm nlst)
        lst (cddr lst))
  (while (or (setq tmp (car lst)) lst)
    (setq nlst (cons tmp nlst)
          lst (cdr lst))
  (reverse nlst)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #2 on: December 27, 2006, 10:44:33 AM »
(defun replase (lst i itm)
  ;;(replase '(0 1 2 3 4 5 6) 3 "A")
  ;; '(0 1 2 "A" 4 5 6)
  (mapcar
    (function
      (lambda (x)
        (if (zerop i)
          (progn (setq i (1- i)) itm)
          (progn (setq i (1- i)) x)
        ) ;_ if
      ) ;_ lambda
    ) ;_ function
    lst
  ) ;_ mapcar
) ;_ defun
« Reply #3 on: December 27, 2006, 10:50:53 AM »
Now that is a pretty solution. :)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #4 on: December 27, 2006, 11:00:45 AM »
(defun replase_1 (lst i itm)
  ;;(replase_1 '(0 1 2 3 4 5 6) 3 "A")
  (if lst
    (if (> i 0)
      (cons (car lst) (replase_1 (cdr lst) (1- i) itm))
      (cons itm (cdr lst))
    ) ;_ if
  ) ;_ if
« Reply #5 on: December 27, 2006, 11:07:22 AM »
Darn it!! Beaten by the recursion master!!
I swear i typed this up just now without seeing Evgeniy's procedure.
(defun nth-replace ( pos new-item lst )
  ;; Nth-Replacer
  ;; This procedure will itterate thru an
  ;; entire list to replace the nth item
  ;; of that list.
  ;; (nth-replace 2 3 '(1 2 4 4))
  ;; (1 2 3 4)
  ;; By: John (Se7en) K
  ;;     12.27.06
  (if (null lst)
    nil
    (cons
      (if (eq pos 0) new-item (car lst))
      (nth-replace (1- pos) new-item (cdr lst)))) )
« Reply #6 on: December 27, 2006, 11:20:36 AM »
I was able to do this variation of Evgeniy's solution.
(defun replace (lst i itm)
  (setq i (1+ i))
  (mapcar
    '(lambda (x)
      (if (zerop (setq i (1- i))) itm x)
    lst
Alas, I feel like I am in the shadows of a Giant.
« Last Edit: December 27, 2006, 11:22:49 AM by CAB »
« Reply #7 on: December 27, 2006, 11:34:05 AM »
I feel like a total newbie. You guys are amazing!
« Reply #8 on: December 27, 2006, 11:39:06 AM »
I like to map out the procedures; its fun.
CAB,
Its funny, because yours, mine, and Evgeniy's are basically the same procedure ...Especially Your last one; Mine and yours are almost identical!
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #9 on: December 27, 2006, 11:41:41 AM »
>CAB
You write excellent programs! I too find new ideas and algorithms in your programs!!!
« Reply #10 on: December 27, 2006, 11:51:19 AM »
Thanks fellas, I just feel a step or two slow at times.  :?
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #11 on: December 27, 2006, 11:54:57 AM »
As alternative...
(defun replase_2 (lst i itm / c)
  ;;(replase_2 '(0 1 2 3 4 5 6) 3 "A")
  (setq c -1)
  (mapcar
    (function cdr)
    ((lambda (l)
       (subst
         (cons 0 itm)
         (assoc i l)
         l
       ) ;_ subst
     ) ;_ lambda
      (mapcar (function (lambda (x) (cons (setq c (1+ c)) x))) lst)
  ) ;_ mapcar
) ;_ defun
terrycadd
Topic of nths of a lists
« Reply #12 on: December 27, 2006, 03:12:14 PM »
On the topic of nths of lists, here is a function that I wrote a long while back. It’s a little bit lengthy, but since it works I never looked into modifying it. Has anyone written a shorter version that does the same thing?
; Move_nth - Moves the nth Num1# item value to the nth Num2# location in a list.
; Arguments: 3
;   Num1# = Nth number in list to move item value
;   Num2# = Nth number in list to move item value of nth Num1# into
;   OldList@ = List to move item values
; Returns: A list with nth item value moved.
(defun Move_nth (Num1# Num2# OldList@ / Cnt# Item NewList@ Num1Value Valid)
  (if (and (= (type Num1#) 'int)(= (type Num2#) 'int)(= (type OldList@) 'list))
    (setq Valid t)
  );if
  (if (and Valid (< Num1# (length OldList@))(< Num2# (length OldList@))
      (/= Num1# Num2#)
    );and
      (setq Cnt# 0)
      (setq Num1Value (nth Num1# OldList@))
      (foreach Item OldList@
        (if (/= Cnt# Num1#)
          (if (< Num1# Num2#)
            (if (/= Cnt# Num2#)
              (if NewList@
                (setq NewList@ (append NewList@ (list Item)))
                (setq NewList@ (list Item))
              );if
                (if NewList@
                );if
                (if NewList@
                  (setq NewList@ (append NewList@ (list Num1Value)))
                  (setq NewList@ (list Num1Value))
                );if
              );progn
            );if
            (if (/= Cnt# Num2#)
              (if NewList@
              );if
                (if NewList@
                );if
                (if NewList@
                );if
              );progn
            );if
          );if
        );if
        (setq Cnt# (1+ Cnt#))
      );foreach
    );progn
    (setq NewList@ OldList@)
  );if
  NewList@
);defun Move_nth
« Last Edit: December 27, 2006, 03:29:37 PM by Terry Cadd »
« Reply #13 on: December 27, 2006, 06:54:55 PM »
How about a Remove the Nth item.
;;  CAB 12/27/2006
;;  (RemoveNth 3 '(0 1 2 3 4 5))
;;  (0 1 2 4 5)
(defun removeNth (i lst)
  (setq i (1+ i))
  (vl-remove-if '(lambda(x) (zerop (setq i (1- i)))) lst)
It's Alive!
  • Retired
  • AKA Daniel
« Reply #14 on: December 27, 2006, 07:20:47 PM »
how about
;;(RemoveNth 3 '(0 1 2 3 4 5))
(if (< i (length lst))
  (vl-remove (nth i lst) lst)
Dan
<KB: added code tags>
« Last Edit: December 27, 2006, 08:37:37 PM by Danielm103 »
