Author Topic: Exploding Multiple Groups  (Read 2235 times)
Big1968dog
« on: May 20, 2004, 02:36:56 PM »
I have alot of groups that have been erased. How can I explode the groups? I would like to explode more the one group at a time. Once you have erased a group, when you select the group it is grayed out and I would like to get rid of it from the list of grouped items. Purge will not work on groups.
TIA
Andrew H
« Reply #1 on: June 02, 2004, 12:30:10 PM »
Have you tried using CDG Purge 3.0? This little purge utility is a nessassary for AutoCAD (and all Autodesk products). It's free and has loads of useful feature. Give it a look.
http://www.caddevelopmentgroup.com/downloads.htm
andyanderson
« Reply #2 on: June 16, 2004, 09:31:40 PM »
A couple of programs come to mind.  I use SuperPurge (from Manusoft.com) to get rid of ALL the junk in a drawing.  I've also got an old lisp routine named XXPLODE that will explode everything down to the last little bit.
