Author Topic: New Blocks: Properties ByWhat?  (Read 9305 times)
M-dub
« on: December 20, 2006, 10:25:33 AM »
I'm sure an argument can be made for each option.  Let's see what you have to say.
Guest
Re: New Blocks: Properties ByWhat?
« Reply #1 on: December 20, 2006, 10:41:00 AM »
Primarily layer 0, but there are a few that have multiple layers defiend, depending on what/how much detail needs to show within other drawings/xrefs.
M-dub
« Reply #2 on: December 20, 2006, 10:42:31 AM »
agreed, but layer is only one of the three main properties you have to set for each block.
CADaver
« Reply #3 on: December 20, 2006, 10:42:47 AM »
it all really depends on the use of the block
Guest
« Reply #4 on: December 20, 2006, 10:50:18 AM »
True dat, true dat... For me, it's primarily layer 0 (bylayer color / linetype) and let the layer that the block is being inserted on take care of the rest.
CADaver
« Reply #5 on: December 20, 2006, 11:04:21 AM »
That only works for block for which it works.  What of blocks that need a multitude of layers within them?
M-dub
« Reply #6 on: December 20, 2006, 11:05:27 AM »
I know what you're saying...
When starting this topic, I was just thinking about the 'simplest' of blocks, though.
Arizona
« Reply #7 on: December 20, 2006, 11:26:53 AM »
Our blocks are created using a multitude of layers. Our colors and linetypes set to bylayer, since we need to show different linetypes and lineweights within one block, but do not have a need to turn off the layers that make up that block. All of our blocks are inserted on 0 layer.
So it comes back to, what are the blocks and how are they used... :-)
Guest
« Reply #8 on: December 20, 2006, 11:28:08 AM »
Oooh! Oooh! Oooh! Oooh! What about..... DYNAMIC BLOCKS?  Huh? Huh??
Arizona
« Reply #9 on: December 20, 2006, 11:31:10 AM »
AutoCAD 2000i
Need I say more... :-(
Guest
« Reply #10 on: December 20, 2006, 11:34:43 AM »
daron
« Reply #11 on: December 20, 2006, 11:52:46 AM »
I was going to say what most people also said when it comes to complex blocks. As for dynamic blocks, I try to use visibility states sparingly. It seems easier to me to just have separate blocks that CAN be controlled easier with a lisp or something.
TimSpangler
  • CAD Naked!!
« Reply #12 on: December 20, 2006, 12:13:23 PM »
I use 2 Layer for blocks
"0" - Shows objects when ploted
"Defpoints" - NonPlot objects such as service area around HVAC or illumination rings around lights tub /  shower traps
Color is usualy "BYLAYER" withthe excesption of 2 screened colors 8 9
Linetype is usually "BYLAYER" with the obvios exceptions (cabinets door swing etc)
ACA 2015 - Windows 7 Pro
Guest
« Reply #13 on: December 20, 2006, 12:26:31 PM »
I refuse to use Defpoints simply because of this...
I've seen this far too many times in drawings.
TimSpangler
  • CAD Naked!!
« Reply #14 on: December 20, 2006, 12:49:25 PM »
I think that used to be a problem:
Applies to:
AutoCAD® 2005
AutoCAD® 2004
Not anymore, I just tested it on ADT06.
I also use non-plotting layers as well but not for block creation.
