Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
VB(A)
Topic:
Log File with Purge command
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Log File with Purge command (Read 1639 times)
Matersammichman
Guest
on:
December 19, 2006, 08:50:20 AM »
I want to create a Log File (.txt) that will record what actions Cad performs from the time a purge command starts, until it is finished, so that I can review what was purged. Has anyone coded this? :kewl:
Last Edit: December 19, 2006, 04:03:03 PM by CmdrDuh
Logged
Bryco
Water Moccasin
Re: Log File
Reply #1 on:
December 19, 2006, 09:54:54 AM »
I can't imaginine you can directly tap into that.
Yor 2 choices are
1)On begin command-tally up everything then find the difference on endcommand
2) Write your own purge command
I've written a purge blocks routine if you need it (that's the hard one)
Logged
rkmcswain
Swamp Rat
WWW
Re: Log File
Reply #2 on:
December 19, 2006, 12:09:02 PM »
Another idea... If you redefine the dialog version of PURGE and force usage of the command line version, then you can review the output from this command.
Explore LOGFILEON, LOGFILEPATH, and LOGFILEOFF
Logged
R.K. McSwain
twitter
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
VB(A)
Topic:
