Author Topic: ( C3D ) I HATE C3D LABELS!!!!!  (Read 12799 times)
Re: ( C3D ) I HATE C3D LABELS!!!!!
« Reply #15 on: February 16, 2007, 05:47:48 PM »
Sometimes I wonder if the spanning feature would be easier to use if it were an 'unconditional span'. You select span and it spans to the ends of the segment no matter what other lines may intersect.
It is unconditional, in that the Label that spans MUST be placed on the outside of the parcel in order to span. If a spanned label is placed inside the parcel, it will not span.
From the Help File:
NoteThis setting applies to parcel line and curve label styles only).
True: Labels the outer boundary of parcels, rather than the individual parcel segments. For example, if four parcels share an outer boundary, use this option to label the combined outer boundary.
