Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
The Third Dimension
Topic:
splines and 3d
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: splines and 3d (Read 5668 times)
Barry Clark
Guest
splines and 3d
on:
December 14, 2006, 03:45:22 PM »
Now, I know I can't extrude a spline... to the best of my knowledge, but I have a drawing that I would like to make a 3d object of with as little fuss as possible. It is made up of splines. Any thoughts on how I can take this object and extude it?
Thanks!
Logged
daron
Guest
Re: splines and 3d
Reply #1 on:
December 14, 2006, 04:23:37 PM »
Copy over your spline with arcs, join them and extrude the arcs? Sorry, I know it's a lot of fuss, but I can't think of any better way.
P.S., I can't tell what version of CAD you're using and haven't tried the spline idea in 2007 yet.
Logged
David Hall
Automatic Duh Generator
King Gator
Re: splines and 3d
Reply #2 on:
December 14, 2006, 04:27:11 PM »
What exactly are you trying to do?
Logged
King Gator
(x-in)->[process]->(y-out) ... simples!
WWW
Re: splines and 3d
Reply #3 on:
December 14, 2006, 04:28:38 PM »
from memory there is a variable setting that says to create splines as poly lines, perhaps you can set this and re-open the drawing and hope it has changed and away you go. Other than that, approximating the spline by tracing it with a polyline would be the simplest answer.
Logged
- John Carmack
- J.R.R. Tolkien
SDETERS
Guest
Re: splines and 3d
Reply #4 on:
December 14, 2006, 05:46:57 PM »
Watch how many endpoints your pline has. The more points on the polyline the more little bitty surfaces you will have.
Logged
dan19936
Guest
Re: splines and 3d
Reply #5 on:
December 14, 2006, 07:50:24 PM »
http://dotsoft.com/public/spl2pl.vlx
will convert splines to plines
Dan
Logged
Bryco
Water Moccasin
Re: splines and 3d
Reply #6 on:
December 14, 2006, 09:00:53 PM »
A closed spline extrudes, Acad 2006, you can also make a region of touching splines and extrude that.
Logged
DaveW
Guest
Re: splines and 3d
Reply #7 on:
April 02, 2007, 11:47:05 AM »
You can also you use the express tools flatten command. That will make arcs, then just pedit and extrude.
Logged
Josh Nieman
Guest
Re: splines and 3d
Reply #8 on:
April 02, 2007, 11:49:41 AM »
at least since 2007 splines could be extruded...
what version you on?
Logged
DaveW
Guest
Re: splines and 3d
Reply #9 on:
April 02, 2007, 12:32:02 PM »
You have always been able to extrude a closed spline or ellipse, as noted above. Acad 2007 allows open splines/ellipses to be extuded and then thickened with the thicken command to create a 3D solid.
Logged
JDMather
Guest
Re: splines and 3d
Reply #10 on:
April 02, 2007, 08:17:43 PM »
http://home.pct.edu/~jmather/content/CAD238/AutoCAD_2007_Tutorials.htm
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
The Third Dimension
Topic:
splines and 3d
