Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Visual DCL Programming
ObjectDCL
Topic:
set text in Multi-line TextBox control..
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: set text in Multi-line TextBox control.. (Read 8367 times)
Andrea
Water Moccasin
WWW
on:
December 12, 2006, 08:02:46 PM »
Hi all,..
I have a simple multi-line TextBox control on a dialog..
and need to add a string on specific line...
I have a string list...and want to fill the multi-line TextBox with this.
but can't found any option...
any idea ?
Logged
Keep smile...
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Re: set text in Multi-line TextBox control..
Reply #1 on:
March 10, 2007, 11:22:51 PM »
Andrea
If you want help with this can you post the ODC and Lisp that you're using.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
ObjectDCL
Topic:
