Author Topic: adding point to a list  (Read 3565 times)
DEVITG
« on: May 15, 2004, 04:19:30 PM »
I'm LISP "lost in ...."
in a WHILE stament  I get diferent points each loop .
I want to join all them in a list , it shall be as point
guess
(Setq  q1  '(26.7685 18.8831 0.0))
(setq q2   '(39.8771 3.60675 0))
I want to have a list such
q3= ((26.7685 18.8831 0.0) (39.8771 3.60675 0)))
If I use
(setq q3 (append q1 q2))
I got (26.7685 18.8831 0.0 39.8771 3.60675 0)
But I want ((26.7685 18.8831 0.0)( 39.8771 3.60675 0))
 :oops:
I SOLVE IT
While doing :Try and error
 it is cons not append , do not why but it is so.
David Bethel
« Reply #1 on: May 15, 2004, 06:38:24 PM »
Try:
(setq q3 (append q1 (list q2)))
(cons) is much faster though.  If the order of the points is important.  (cons) everything together and then (reverse) the final list.
-David
R12 Dos - A2K
DEVITG
« Reply #2 on: May 15, 2004, 07:05:58 PM »
But q2 is a list yet , how does it work
« Reply #3 on: May 15, 2004, 07:49:34 PM »
Devitg, Dont be confused by what the list actualy is and what the intripriter displays. The intripriter will display anything that it thinks as a list wraped in Paren's.
David Bethel
« Reply #4 on: May 16, 2004, 08:11:46 AM »
Yes,q2 is a list, but in your case, you want the list q2 to become an atom in another list q3.  q3 has 2 atoms q1 and q2, both of which happen to be lists.
(append existing_list ( list_of_new_atoms ))
-David
R12 Dos - A2K
« Reply #5 on: May 16, 2004, 08:30:16 AM »
DEVITG
In this case you want to use LIST.
(setq q3 (list q1 q2))
Now if you want to add to the list q3
(setq q0 '(0.0 0.0 0.0))
(setq q3 (cons q0 q3))
((0.0 0.0 0.0) (26.7685 18.8831 0.0) (39.8771 3.60675 0))
; but not
(setq q3 (cons q3 q0))
(((26.7685 18.8831 0.0) (39.8771 3.60675 0)) 0.0 0.0 0.0)
You could do this
(setq q3 '())
nil
_$ (setq q3 (cons q1 q3))
((26.7685 18.8831 0.0))
_$ (setq q3 (cons q2 q3))
((39.8771 3.60675 0) (26.7685 18.8831 0.0))
_$ (setq q3 (cons q0 q3))
((0.0 0.0 0.0) (39.8771 3.60675 0) (26.7685 18.8831 0.0))
DEVITG
« Reply #6 on: May 16, 2004, 11:01:38 AM »
Hi all , thanks for your help.  following is how I solve it , with your help , of course :D  :?
(setq invpt ())
(WHILE (< IR (+ RE 0.005))
;process to get the new x y z points
(setq q2 (list IRX IRY ZPT))
(setq invpt (cons q2 invpt));
  (setq x (+ x st))
);_end while
