Author Topic: Can I make it any tougher?  (Read 4839 times)
« on: December 08, 2006, 07:13:47 PM »
I guess I have a complete mental block on this C# language. Try as I might, I cannot get this to work. Everything goes fine until I want to output what I'm doing to the command line......at which point I get a major error thrown in Acad. I'll try to capture a PNG of the error in a few minutes.
            PromptDistanceOptions distPrmt = new PromptDistanceOptions("");
            distPrmt.Message = "\nOffset distance, negative for left side: ";
            distPrmt.DefaultValue = 5.0;
            PromptDoubleResult offDist = ed.GetDistance(distPrmt);
            ed.WriteMessage(offDist.Value.ToString());
In Debug mode I can see the offDist variable get set to {{OK}, 15.0} and I can inspect it and see that the value is 15.0. But once it gets to the WriteMessage line, Kaboom. Anyone (everyone) care to tell me what the heck I'm missing?  :|
Re: Can I make it any tougher?
« Reply #1 on: December 08, 2006, 07:22:14 PM »
Jeff ,
How is ed defined ?
What is the exception ?
« Reply #2 on: December 08, 2006, 07:26:22 PM »
Jeez, now it works.....I guess I didn't rebuild it after changing this line:
from this:
ed.WriteMessage(offDist.Value.ToString("D"));
So now my question is this, how do I format the Value to output like this: 15.00' ? As it is now, it prints just 15 to the command line.
Kerry,
            Document doc = acadApp.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
The exception is:
MickD
« Reply #3 on: December 08, 2006, 07:33:01 PM »
just try sending it to writeline as offsetdist.value (not ToString()) and write line should be able to format it appropriately (I think from memory)
- John Carmack
- J.R.R. Tolkien
« Reply #4 on: December 08, 2006, 07:33:22 PM »
« Reply #5 on: December 08, 2006, 07:35:25 PM »
Having fun ?
In Debug mode I can see the offDist variable get set to {{OK}, 15.0} ...
good to see you got the debugger working in Express !
« Last Edit: December 08, 2006, 07:37:12 PM by Kerry Brown »
« Reply #6 on: December 08, 2006, 07:45:04 PM »
Jeff, I'll have a look at the ToString Override for you ..
Autodesk.AutoCAD.EditorInput.PromptResult.ToString(IFormatProvider) : String
I think that should work ...
« Reply #7 on: December 08, 2006, 07:49:55 PM »
Just an aside,
I've found this really handy
 - .NET Reflector, Version 4.2.50.0
http://www.aisto.com/roeder/dotnet/
Just load up :-
C:\ACAD2007\acmgd.dll
C:\ACAD2007\acdbmgd.dll
C:\ACAD2007\acmgdinternal.dll
%SystemRoot%\Microsoft.net\Framework\vxxxxx\System.Windows.Forms.dll
%SystemRoot%\Microsoft.net\Framework\vxxxxx\mscorlib.dll
Great for rainy weekends :-)
« Last Edit: December 09, 2006, 02:28:42 AM by Kerry Brown »
« Reply #8 on: December 08, 2006, 08:10:58 PM »
OK....
Mick, yes I tried that and it still only outputs what it wants. In this case it should be 15.00 but I only get 15 at the prompt.
Kerry, I've got lots of reading now, thanks. :-)
Tim, thanks for the link. Based on the discussion there I was able to get "N2" to work. "D2" throws the exception, but the Help says that d,D,n,N are all valid Format identifiers.......
Here's a quickie test that shows these in action:
using System;
using System.Text;
using acadApp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace SelectFeature
    public class Class1
        public Class1()
        [CommandMethod("TestMe1")]
        static public void testmenow()
            ed.WriteMessage("Test1 Offset selected is: " + offDist.Value);
        [CommandMethod("TestMe2")]
            ed.WriteMessage("Test2 Offset selected is: " + offDist.Value.ToString("N2"));
        [CommandMethod("TestMe3")]
            ed.WriteMessage("Test3 Offset selected is: " + offDist.Value.ToString("D2"));
This will create 3 commands, TestMe1, TestMe2 & TestMe3. 1 & 2 will work, but 3 should throw that exception.
I'm off to take some aspirin. This little problem has kicked my behind for 2 hours now......
BTW, Kerry, how'd you know we were going to be rained on all weekend?
LE
« Reply #9 on: December 08, 2006, 09:05:22 PM »
Two hours?..... it is nothing....  :-P
See if the code below helps.... you can change the format inside of the ToString("0.00") to change the precision, but do not if that is what you are looking for, I remember reading a comment by Tony Tanzillo about this issue, in the adesk net.... but do not have the link.
            if (offDist.Status != PromptStatus.OK) return;
            ed.WriteMessage("Test3 Offset selected is:  " + offDist.Value.ToString("00.00"));
« Reply #10 on: December 08, 2006, 09:17:38 PM »
heheheheh
one of my lesser talents :lol:
There MUST be a method in the NET API to format inits .. distance or somesuch .. I'll have a look this afternoon if no-one sorts it out ..
LE
« Reply #11 on: December 08, 2006, 09:41:42 PM »
No samples out there.... now base on what Tony Tanzillo recommended, I went into the VS2005 IDE and click into the Class View icon, and on the View Class Diagram for the Autodesk.AutoCAD.Runtime
And we can use something like this:
string output = Converter.DistanceToString(offDist.Value, DistanceUnitFormat.Decimal, 2);
ed.WriteMessage("Test3 Offset selected is:  " + output);
r&r
« Last Edit: December 08, 2006, 11:08:55 PM by LE »
« Reply #12 on: December 08, 2006, 10:35:36 PM »
Nice investigation Luis !
LE
« Reply #13 on: December 08, 2006, 11:11:44 PM »
Yes... I'm trying to put good use of all the free time I have now... :)
