Seven, the buttons are FAAAAAARRRRR perdier. Here's a menu with the layer toolbar:
![](http://www.theswamp.org/super.fusion/Images/towebuploads/menustucture.jpg)
and here's a tool pallette. You've seen these.
![](http://www.theswamp.org/super.fusion/Images/towebuploads/pallette.jpg)
BDC can be downloaded from
http://cadencoding.com/Here's something I don't like. Ever use layer states. As far as I can tell, they're only to be had on the command line. They've been removed from the layer dialog box, at least in ADT. I think they've been replaced with screenshots. Speaking of the layer dialog box, filtering has been improved.
Now for something different, ADT! Take a look at the menu image, you'll notice that the ADT content isn't as far removed from the core of ACAD as it has been in the past. Notice there are only two menu's that are familiar to what you're used to in ADT. Many of the ADT items are in Format. The whole thing has been integrated better. ...-----...----- This just in, under help there is now documentation on ADT ActiveX Help. I assume the same is correct for other VP's. WooHooooo. I got's me some readin' to do. Manipulatin' the ADT object model, here I come.
