Author Topic: Update Last Dimension  (Read 2390 times)
Matersammichman
« on: December 08, 2006, 03:23:25 PM »
DimUpdate doesn't exist in vba, and I can't get SendCommand to release, so how do I Update a dimension?
ska67can
Re: Update Last Dimension
« Reply #1 on: December 08, 2006, 03:42:56 PM »
Lets see your code.
David Hall
  • Automatic Duh Generator
« Reply #2 on: December 08, 2006, 03:45:58 PM »
my guess w/o seeing your code would be to store the style name and select dims and re-assign them the style name forcing an update
Matersammichman
« Reply #3 on: December 08, 2006, 03:46:17 PM »
ThisDrawing.SendCommand "dim" & vbCr & "up" & vbCr & "l" '& vbCr '
Atook
  • AKA Tim
« Reply #4 on: December 08, 2006, 03:56:43 PM »
Dim objdim As AcadDimension
    objdim.Update
does .update not work?
Matersammichman
« Reply #5 on: December 08, 2006, 04:19:41 PM »
No.
Cathy
« Reply #6 on: December 08, 2006, 04:55:37 PM »
Do you need to update because you've changed the dimstyle?
Dimensions created via the AutoCAD user interface are created with the active dimension style plus all document overrides. Dimensions created via ActiveX are created with the active dimension style only. To have the dimensions created via ActiveX take on the document overrides, use the CopyFrom method to copy the dimension style from the document to the active dimension style. This process will copy all existing overrides into the active dimension style.
     ThisDrawing.SetVariable "LUNITS", 2
     ThisDrawing.SetVariable "LUPREC", 2
     ThisDrawing.SetVariable "DIMLUNIT", 2
     ThisDrawing.SetVariable "DIMDEC", 2
    objDimStyle.CopyFrom ThisDrawing
    ThisDrawing.ActiveDimStyle = objDimStyle
Matersammichman
« Reply #7 on: December 08, 2006, 05:26:05 PM »
Yes. I changed the parameters within the Dimstyle
Cathy
« Reply #8 on: December 09, 2006, 12:03:27 PM »
and did you copy the changes to the activedimstyle as above?
ska67can
« Reply #9 on: December 09, 2006, 10:54:27 PM »
I meant all you code
Matersammichman
« Reply #10 on: December 11, 2006, 07:43:19 AM »
Thanks Cathy. Your suggestion worked.
