Author Topic: Shape Files  (Read 3500 times)
dukesys
Shape Files
« on: December 07, 2006, 06:07:00 PM »
Hello All,
Does anybody out there know how to load a shape file using .NET.  The only reference I have found to shapes so far, is a property of the TextStyleTableRecord called IsShapeFile.  I cannot work out yet how to use this, can anyone help me?
Regards
Martin.
Glenn R
Re: Shape Files
« Reply #1 on: December 07, 2006, 07:00:56 PM »
It appears that when you manually load a shape file with the "LOAD" command, it creates a new AcDbTextStyleTableRecord/TextStyleTableRecord with a blank name...I just loaded 2 shape files this way.
So you could try creating a new TextStyleTableRecord, give it a blank name and the shx file to use.
Give it a whirl and lert me know how it goes.
Cheers,
Glenn.
dukesys
Re: Shape Files
« Reply #2 on: December 07, 2006, 07:46:19 PM »
Glenn,
I tried a blank name, i.e. not setting the .Name value and also setting it to "" and neither works!  any other ideas?  To explain further why this is important, I am loading in custom linestyles with custom shapes in them.
Cheers
Martin.
Glenn R
Re: Shape Files
« Reply #3 on: December 07, 2006, 08:20:46 PM »
Try a space Martin...it's hard to tell what it is in the dialog here...
Glenn R
Re: Shape Files
« Reply #4 on: December 07, 2006, 08:34:54 PM »
Give this a run 'round the yard:
[CommandMethod("ShapeTest")]
static public void ShapeTestCommand( )
string shapeFileName = @"C:\Temp\Cfm.shx";
Database db = doc.Database;
TextStyleTable ts = tr.GetObject(db.TextStyleTableId, OpenMode.ForWrite, false) as TextStyleTable;
TextStyleTableRecord tstr = new TextStyleTableRecord();
tstr.FileName = shapeFileName;
tstr.IsShapeFile = true;
ts.Add(tstr);
tr.AddNewlyCreatedDBObject(tstr, true);
tr.Commit();
Cheers,
Glenn.
