Author Topic: PlottingServices help  (Read 11371 times)
mohnston
  • CAD Programmer
Re: PlottingServices help
« Reply #15 on: December 07, 2006, 11:25:47 AM »
Thanks for the suggestion.
Unfortunately I tried it but got the same error.
Void Check(Int32)
   at Autodesk.AutoCAD.Runtime.Interop.Check(Int32 returnValue)
   at Autodesk.AutoCAD.PlottingServices.PlotInfoValidator.Validate(PlotInfo info)
   at PlotNET.PlotterClass.NETPlot() in M:\Programming\Projects\ACAD_Development\PlotNET\PlotNET\Class.cs:line 106
CAD Programming Solutions
mohnston
  • CAD Programmer
« Reply #16 on: December 07, 2006, 05:26:58 PM »
forgot this:
pInfo.Layout = LayoutManager.Current.GetLayoutId("Model");
 :ugly:
P.S. - If you are a VB programmer that is just getting your head around C# and someone says that you can convert C++ code to C# if you "just change -> to ." it is good to remember that the person making the suggestion knows both C++ and C# whereas you don't. Unless you know C++ you will likely hurt your brain when attempting such a maneuver, possibly bashing it into a ::.
« Last Edit: December 07, 2006, 05:33:00 PM by mohnston »
LE
« Reply #17 on: December 07, 2006, 05:39:22 PM »
I am moving into C#, and have been able to port most of my code in C++/ARX to C#, but not by simple replacing the -> for . - it requires more than that, at least for me... (I even have been able to port VB to C# - and it is much easier - but I do not know much about VB)
What, sample in the SDK are you porting?
Glenn R
« Reply #18 on: December 07, 2006, 07:03:00 PM »
Mark, have you gotten it to work or would you like and example of how to use a pagesetup...that's the way I do it.
mohnston
  • CAD Programmer
« Reply #19 on: December 08, 2006, 11:15:46 AM »
I was really just trying to understand the plotting code.
What ended up helping me was porting from a script file to C#.
That showed me I was missing the Layout.
Glenn,
I do have something working but I would really appreciate an example of using pagesetup since that was my first inclination.
mohnston
  • CAD Programmer
« Reply #20 on: December 08, 2006, 12:06:22 PM »
Maybe this will help someone since there really isn't very much in the way of documentation on the PlottingServices.
        [CommandMethod("CSharpPlot")]
        static public void CSharpPlot()
            // Set up some variables
            string fullDWGPath = @"C:\PlotTestFile.dwg";
            Document ThisDrawing = Application.DocumentManager.Open(fullDWGPath, true);
            Database ThisDB = ThisDrawing.Database;
            int Copies = 1;
            Object parms = null;
            string plotDeviceName = "myValidPlotDevice.pc3";
            string styleSheet = "myValidStyleSheet.ctb";
            Point2d originPoint = new Point2d(0, 0);
            // Set up some PLOT specific variables
            PlotInfo pInfo = new PlotInfo();
            PlotSettings pSet = new PlotSettings(true);
            PlotSettingsValidator pSetValid = PlotSettingsValidator.Current;
            PlotPageInfo pPInfo = new PlotPageInfo();
            PlotConfigManager.SetCurrentConfig(plotDeviceName);
            PlotConfigManager.RefreshList(RefreshCode.All);
            // set the Canonical Media Name (paper name) - for sample purposes just grab the first one
            StringCollection cMNs = PlotConfigManager.CurrentConfig.CanonicalMediaNames;
            string mediaName = cMNs[0].ToString();
            try
                pSetValid.SetPlotConfigurationName(pSet, plotDeviceName, mediaName);
                // It was recommended to refresh lists before changing settings
                pSetValid.RefreshLists(pSet);
                pSetValid.SetCurrentStyleSheet(pSet, styleSheet);
                pSetValid.SetPlotCentered(pSet, false);
                pSetValid.SetPlotOrigin(pSet, originPoint);
                pSetValid.SetPlotPaperUnits(pSet, PlotPaperUnit.Inches);
                pSetValid.SetPlotRotation(pSet, PlotRotation.Degrees000);
                pSetValid.SetPlotType(pSet, Autodesk.AutoCAD.DatabaseServices.PlotType.Limits);
                pSetValid.SetUseStandardScale(pSet, true);
                pSetValid.SetStdScaleType(pSet, StdScaleType.StdScale3To8InchIs1ft);
                pSetValid.SetZoomToPaperOnUpdate(pSet, false);
                // apply setting overrides to plot info
                pInfo.OverrideSettings = pSet;
                PlotInfoValidator pInfoValid = new PlotInfoValidator();
                pInfoValid.MediaMatchingPolicy = MatchingPolicy.MatchEnabled;
                pInfoValid.Validate(pInfo);
                // Settings are set - attempt plot
                PlotProgressDialog pProgDialog = new PlotProgressDialog(false, 1, true);
                //PlotProgressDialog pProgDialog = new PlotProgressDialog(true, 1, true); // In case it's a preview
                pProgDialog.OnBeginPlot();
                pProgDialog.IsVisible = true;
                PlotEngine pEng = PlotFactory.CreatePublishEngine();
                //PlotEngine pEng = PlotFactory.CreatePreviewEngine(1); // In case it's a preview
                pEng.BeginPlot(pProgDialog, parms);
                pEng.BeginDocument(pInfo, fullDWGPath, parms, Copies, false, string.Empty);
                // pEng.BeginDocument(pInfo, fullDWGPath, parms, Copies, true, fullPLTPath); // In case plot to file
                pEng.BeginPage(pPInfo, pInfo, true, parms);
                pEng.BeginGenerateGraphics(parms);
                pEng.EndGenerateGraphics(parms);
                pEng.EndPage(parms);
                pEng.EndDocument(parms);
                pEng.EndPlot(parms);
                pProgDialog.OnEndPlot();
                pProgDialog.Destroy();
                pEng.Destroy();
            catch (Autodesk.AutoCAD.Runtime.Exception e)
                System.Windows.Forms.MessageBox.Show(e.TargetSite + "\n" + e.StackTrace);
smcclure
« Reply #21 on: January 09, 2007, 03:45:16 PM »
Are you using 2007? I had some plot code that worked just fine in 2005, and completely bombs in 2007 (causes a fatal exception and corrupts the current profile....) Has anyone experienced similar trouble with 2007 for plotting compared to previous versions?
 - Scott
mohnston
  • CAD Programmer
« Reply #22 on: January 09, 2007, 08:08:55 PM »
 - Scott
AutoCAD 2007
VS 2005
David Hall
  • Automatic Duh Generator
« Reply #23 on: July 31, 2009, 01:23:32 PM »
So has anybody updated plotting for 2010 yet?
David Hall
« Reply #24 on: July 31, 2009, 04:10:17 PM »
I copied this from Kean W (Through the Interface) and made changes to plot to my machine.  Seems really really slow though
using Autodesk.AutoCAD.PlottingServices;
namespace PlottingApplication
    public class PlottingCommands
        [CommandMethod("simplot")]
        static public void SimplePlot()
            Editor ed = doc.Editor;
            Database db = doc.Database;
            Transaction tr = db.TransactionManager.StartTransaction();
            using (tr)
                // We'll be plotting the current layout
                BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead);
                Layout lo = (Layout)tr.GetObject(btr.LayoutId, OpenMode.ForRead);
                // We need a PlotInfo object
                // linked to the layout
                PlotInfo pi = new PlotInfo();
                pi.Layout = btr.LayoutId;
                // We need a PlotSettings object
                // based on the layout settings
                // which we then customize
                PlotSettings ps =
                new PlotSettings(lo.ModelType);
                ps.CopyFrom(lo);
                // The PlotSettingsValidator helps
                // create a valid PlotSettings object
                PlotSettingsValidator psv = PlotSettingsValidator.Current;
                // We'll plot the extents, centered and
                // scaled to fit
                psv.SetPlotType(ps, Autodesk.AutoCAD.DatabaseServices.PlotType.Extents);
                psv.SetUseStandardScale(ps, true);
                //psv.SetStdScaleType(ps, StdScaleType.ScaleToFit);
                psv.SetStdScaleType(ps, StdScaleType.StdScale1To1);
                psv.SetPlotCentered(ps, true);
                // We'll use the standard DWF PC3, as
                // for today we're just plotting to file
                psv.SetPlotConfigurationName(ps, "2010 Oce.pc3", "ARCH_expand_D_(36.00_x_24.00_Inches)");
                //psv.SetPlotConfigurationName(ps, "DWF6 ePlot.pc3", "ANSI_A_(8.50_x_11.00_Inches)");
                // We need to link the PlotInfo to the
                // PlotSettings and then validate it
                pi.OverrideSettings = ps;
                PlotInfoValidator piv = new PlotInfoValidator();
                piv.MediaMatchingPolicy = MatchingPolicy.MatchEnabled;
                piv.Validate(pi);
                // A PlotEngine does the actual plotting
                // (can also create one for Preview)
                if (PlotFactory.ProcessPlotState == ProcessPlotState.NotPlotting)
                    PlotEngine pe = PlotFactory.CreatePublishEngine();
                    using (pe)
                        // Create a Progress Dialog to provide info
                        // and allow thej user to cancel
                        PlotProgressDialog ppd = new PlotProgressDialog(false, 1, true);
                        using (ppd)
                            ppd.set_PlotMsgString(PlotMessageIndex.DialogTitle, "Custom Plot Progress");
                            ppd.set_PlotMsgString(PlotMessageIndex.CancelJobButtonMessage, "Cancel Job");
                            ppd.set_PlotMsgString(PlotMessageIndex.CancelSheetButtonMessage, "Cancel Sheet");
                            ppd.set_PlotMsgString(PlotMessageIndex.SheetSetProgressCaption, "Sheet Set Progress");
                            ppd.set_PlotMsgString(PlotMessageIndex.SheetProgressCaption, "Sheet Progress");
                            ppd.LowerPlotProgressRange = 0;
                            ppd.UpperPlotProgressRange = 100;
                            ppd.PlotProgressPos = 0;
                            // Let's start the plot, at last
                            ppd.OnBeginPlot();
                            ppd.IsVisible = true;
                            pe.BeginPlot(ppd, null);
                            // We'll be plotting a single document
                            pe.BeginDocument(
                                 pi,
                                  doc.Name,
                                   null,
                                    1,
                                    false,
                                //true, // Let's plot to file
                                      "c:\\test-output"
                            // Which contains a single sheet
                            ppd.OnBeginSheet();
                            ppd.LowerSheetProgressRange = 0;
                            ppd.UpperSheetProgressRange = 100;
                            ppd.SheetProgressPos = 0;
                            PlotPageInfo ppi = new PlotPageInfo();
                            pe.BeginPage(
                                 ppi,
                                  pi,
                                   true,
                                    null
                            pe.BeginGenerateGraphics(null);
                            pe.EndGenerateGraphics(null);
                            // Finish the sheet
                            pe.EndPage(null);
                            ppd.SheetProgressPos = 100;
                            ppd.OnEndSheet();
                            // Finish the document
                            pe.EndDocument(null);
                            // And finish the plot
                            ppd.PlotProgressPos = 100;
                            ppd.OnEndPlot();
                            pe.EndPlot(null);
                else
                    ed.WriteMessage(
                         "\nAnother plot is in progress."
wannabe
« Reply #25 on: August 01, 2009, 05:47:01 AM »
Have you checked out the .NET Developers guide? :wink:
David Hall
« Reply #26 on: August 02, 2009, 03:22:41 PM »
I did check the developers guide, and found a similiar post of code.  I did find that I "thought" I had disabled background plotting, but had not, which is why it seemed so slow
