Well, hopefully they will improve dyna blocks to include 3d features and work out the bugs that have been presented here and I'm sure at AUGI. I hope they improve their vertical platforms too. ADT roof structures and slabs are in dire need of overhauls. They also need to consider the KISS format. It has become very cumbersome and complicated. Each release they change things and you have to relearn. They don't just improve it, they change how you do it. And the help files, if anything should be changed, these should either be helpful, or to keep things simple for Autodesk, change the name of these files to the "Boast" files. Every time I need help with something, I check the help files, and all I read is how great this feature is. Nothing in there tells me how I'm supposed to use it, just a few things about what the feature can do for productivity and only the stuff on the surface that got me to the point where I'm needing help. So, needless to say, I've spent a lot of time searching google for an article or 5 that someone was so gracious to write up explaining it. As for productivity, I'm sure I'll get there, when I've fully learned how to use ADT. And they wonder why people haven't fully embraced ADT or Revit.
:realmad: :realmad: :realmad: Thanks for asking that question. Guess I needed to vent.
