Author Topic: tub size  (Read 3829 times)
  • Custom Title
tub size
« on: May 13, 2004, 02:51:56 PM »
can one of you archT types tell me what size opening a standard tub takes? someone i know is doing some remodeling and needs that info.
thanks
David Bethel
tub size
« Reply #1 on: May 13, 2004, 03:46:08 PM »
Mark,
They are noramlly 60" wide.
Check out Kohler's web site.  They have a lot of CAD libriares to download.
-David
PS I had to reregister.  I guess the first one had an error or didn't get through ?????
http://www.kohler.com
R12 Dos - A2K
tub size
« Reply #2 on: May 13, 2004, 03:48:29 PM »
Mark,
I gotta friend that drafts houseplans. He told me 30''x60".
HTH
Ron
  • Custom Title
tub size
« Reply #3 on: May 13, 2004, 04:03:35 PM »
thanks guys.............
Dent Cermak
tub size
« Reply #4 on: May 13, 2004, 05:03:05 PM »
UNLESS YOU GOT A BIG BUTT LIKE MINE. THEN THE 30" DIMENSION CALLS FOR GREASING UP !!
Dommy2Hotty
tub size
« Reply #5 on: May 13, 2004, 05:14:06 PM »
Quote from: ronjonp
Mark,
HTH
Ron
Our standard Tub/Shower block is 32"x60"
Here is our block for you ~ R1023
tub size
« Reply #6 on: May 13, 2004, 05:20:31 PM »
Kohler Villiger Cast Iron 60x30.25x14  typical tub
Kohler Mendota Cast Iron 60x32x16.25   special size
Generic Steel tub 60x30x15  height varies from mfg to mfg. +/- 1"
  • Custom Title
tub size
« Reply #7 on: May 13, 2004, 05:24:40 PM »
thanks again.
M-dub
tub size
« Reply #8 on: May 14, 2004, 08:13:30 AM »
Just yesterday, I put in a new tub that was 60" x 32", but that was only half the fun.  I had to take a sledge hammer to the original tub to get it out.  Cast iron...must have weighed at least 500 lbs (in one piece).  I think my house must have been built around the tub!
So...60"x32"...but they come in all different sizes.
tub size
« Reply #9 on: May 14, 2004, 09:32:09 AM »
Well, since I am a little slow in getting to these posts, I will just have to say that I concur...
However, most home building supply warehouses (i.e. Lowes, Home Depot, etc.) carry in stock actually 3 different "standard" size tubs. That is:
30X54
30X60
32X60
Now that being said, the most common size I have seen in my 17 years ofo residential construction is the 30X60, although I have seen some builders that would not use anything except a 32X60.
There are also other size tubs available from nationally known manufacturers typically ranging in 6" increments in length from 54" to 84" and widths from 30" to 36" in 2" increments.
just my .02 worth
Dent Cermak
tub size
« Reply #10 on: May 14, 2004, 01:07:18 PM »
Well, you can't put a 36" butt in a 30" tub. I know. Makes a horrible "slurping" sound when you stand up.
M-dub
tub size
« Reply #11 on: May 14, 2004, 01:09:12 PM »
Quote from: Dent Cermak
...horrible "slurping" sound when you stand up.
 :lol: LOL  :lol:
I know that sound!  :wink:
t-bear
tub size
« Reply #12 on: May 14, 2004, 01:45:33 PM »
TUB?  Don't need no stinkin' tub!  Jus' jump in th' river....make sure the horse an' dogs is downstream....
Don't git no slurpin' noises that way neither. Ahhhh, the Ozarks!
tub size
« Reply #13 on: May 14, 2004, 04:02:18 PM »
Hey!!! I went a dippin' once in Dry Shop Creek (when it was wet), in Newton County AR
