Author Topic: What template was used?  (Read 1229 times)
Guest
« on: December 04, 2006, 10:39:12 AM »
Is there a way to determine what template file was used to create a drawing?
sinc
Re: What template was used?
« Reply #1 on: December 04, 2006, 12:56:22 PM »
Not definitively.  You basically need to use visual inspection of the DWG.
Autocad does not maintain any sort of link between a DWG and its template (although it probably should).
Guest
« Reply #2 on: December 04, 2006, 01:34:14 PM »
*sigh*   :-(
rkmcswain
« Reply #3 on: December 04, 2006, 02:16:47 PM »
I suppose you could put your own tracking mechanism in your template(s). Maybe a dictionary or xdata....
Then you could query that info down the road....
