Author Topic: Get point from cursor  (Read 1964 times)
Adesu
« on: December 04, 2006, 02:41:44 AM »
Hi Alls,
Does anyone have a code to get point from cursor,I mean if user ,put cursor any location in drawing area,then get a point,and it don't hit,only move as user require.
« Last Edit: December 04, 2006, 09:37:51 PM by Adesu »
Re: get point from cursor
« Reply #1 on: December 04, 2006, 04:18:16 AM »
I believe you want to use GRREAD. Do a quick search in this forum, you should find many topics.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #2 on: December 04, 2006, 06:14:59 AM »
Hi Alls,
(defun c:test (/ gr)
  (alert "for exit, press \"Esc\"")
  (while (setq gr (grread nil 7))
    (princ (cadr gr))
    (prin1)
  ) ;_ while
) ;_ defun
Adesu
« Reply #3 on: December 04, 2006, 06:46:05 PM »
Hi Elpanov,
Yes it's great,and that code as I looking for,many thanks for your help.
