Author Topic: vlax-curve-getClosestPointTo Problem  (Read 2278 times)
Lemank
« on: December 03, 2006, 11:34:29 AM »
Hi -
I am trying to communicate between VBA and VLisp to use the vlax-curve functions using the setlispvar and evallispexpression code. I cannot seem to get the code to work properly. The attached file contains my code. The code attempts to draw a line from (0,0,0) to (100,100,0), then find the closest point to (50,55,0). The problem seems to be in translating the point variant to a point list. Any help would be greatly appreciated as I am thoroughly frustrated and "brain dead" at this point, knowing that I am overlooking something very obvious or doing something very dumb!!
Thanks in advance
Re: vlax-curve-getClosestPointTo Problem
« Reply #1 on: December 03, 2006, 01:42:31 PM »
Here's a snip of code from Frank Oquendo's VLAX.CLS that handles setting lisp symbols. Note how it differs from yours in that he uses lisp functions to convert the data types.
Public Sub SetLispSymbol(symbolName As String, value)
    Dim sym As Object, ret, symValue
    symValue = value
    Set sym = VLF.Item("read").funcall(symbolName)
    ret = VLF.Item("set").funcall(sym, symValue)
    EvalLispExpression "(defun translate-variant (data) (cond ((= (type data) 'list) (mapcar 'translate-variant data)) ((= (type data) 'variant) (translate-variant (vlax-variant-value data))) ((= (type data) 'safearray) (mapcar 'translate-variant (vlax-safearray->list data))) (t data)))"
    EvalLispExpression "(setq " & symbolName & "(translate-variant " & symbolName & "))"
    EvalLispExpression "(setq translate-variant nil)"
End Sub
Bryco
« Reply #2 on: December 03, 2006, 02:45:06 PM »
I use  Frank's class,it's easy to use and does what you need.
(I'm on 2006, I haven't tried it on 2007)
' Curve.cls v1.3 (Last updated 12/18/2001)
' Copyright 2000, 2001 by Frank Oquendo
Lemank
« Reply #3 on: December 05, 2006, 08:05:18 PM »
Thanks guys!!
I appreciate the tips. I am still trying to resolve the problem. I have tried the Curve class with some success. It seems to work fine for my test drawing which has only a few Aecc points at coordinates with values less than 10,000. I tried it on a larger drawing with about 300 points at state plane coordinates of 10,000,000 for x and 3,000,000 for y and it gives an error message at different points with no consistency. If I translate the points to values less than 10,000, it works flawlessly for the 300 points. Could the problem be with some values being expressed in scientific notation because I keep getting error code 13?
Anyway, I will keep playing with it. Thanks again for your help!!!
Bryco
« Reply #4 on: December 05, 2006, 09:21:11 PM »
Cad itself has problems offsetting when you are too far from the origin and vba's low  accuracy doesn't help much.
If you only want closest point I will post some code w/ math that I like better.
