Author Topic: ( Challenge ) Just curious  (Read 18849 times)
Re: ( Challenge ) Just curious
« Reply #15 on: December 01, 2006, 05:17:53 PM »
Holy Katz, Tim! Is my laptop really that slow?. <grumble.wav>
Intel(R)Xeo (processor?)
2.8GHz
1Gb Ram
I have Lotus Notes, Outlook 6, Firefox, Exploer,  Winamp (ssshh!! don't tell my boss) AutoCAD Electrial '06 running at the time tested.
« Reply #16 on: December 01, 2006, 07:04:47 PM »
Jeff,  Alan ,
I've noticed that some of the others are opening the file before they start the timer .... that may shave a little bit off if you are concerned about time.
« Reply #17 on: December 01, 2006, 07:20:18 PM »
Thanks for the thought, Kerry. Although it doesn't save all that much...:
  (setq timer (getvar "millisecs"))
  (setq file1 (open "C:\\Base Maps\\Jeffs Test Files\\junk\\numbers.csv" "R"))
  (close file1)
  (princ (strcat "Process took " (rtos (/ (- (getvar "millisecs") timer) 1000.0) 2 2) " seconds."))
Process took 0.03 seconds.
Of course I guess this just proves that Lisp was not designed to work, at least not quickly, with large data sets.
« Reply #18 on: December 01, 2006, 07:57:59 PM »
Still, 2.5 seconds is not too slouchfull for an interpreted language ..
read 10,000 line of text with 10 values each line
translate text in each line to numbers
evaluate min
evaluate max
write values to file
rinse and repeat ....
.... there's a lot going on there ....
Andrea
« Reply #19 on: December 01, 2006, 08:31:28 PM »
there is mine...
(defun c:minmax (/ start-time f1 l1 lineM #low #hi newfile end-time fr)
(setq f1 (open (getfiled "Please select your file..." "" "csv" 8) "r")
      l1 (read-line f1))
(setq start-time (getvar "cdate"))
(if l1 (setq newfile (open "c:\\result.txt" "w")))
(while l1
(setq lineM (read (strcat "(" (acet-str-replace "," " "  l1) ")"))
       #low (car (vl-sort lineM '<))
        #hi (car (vl-sort lineM '>)))
(write-line (strcat (rtos #hi) " " (rtos #low)) newfile)
(setq l1 (read-line f1)))
(close f1)
(close newfile)
(setq end-time (getvar "cdate")
fr (substr (rtos (- end-time start-time) 2 10) 7))
(alert (strcat "Done in only ..." (substr fr 1 2) "," (substr fr 3) " sec."))
Keep smile...
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #20 on: December 02, 2006, 04:46:42 AM »
:-o
for my pc...
  ;;Jeff_M
  (repeat 100
  (setq
    file1 (open "D:\\numbers.csv"
                "R"
          ) ;_ open
  ) ;_ setq
  (close file1)
  (princ
            (rtos (/ (- (getvar "millisecs") timer) 1000.0) 2 4)
            " seconds."
    ) ;_ strcat
  ) ;_ princ
repeat 100:
Process took 0.015 seconds.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #21 on: December 02, 2006, 06:20:45 AM »
(defun c:test_1 (/ f timer)
  ;;(c:test_1)
  ;; ElpanovEvgeniy
  (defun pars (s f f1)
    (if s
        ((lambda (l)
           (if (< (car l) (cadr l))
             (min_max (car l) (cadr l) (cddr l) f1)
             (min_max (cadr l) (car l) (cddr l) f1)
           ) ;_ if
         ) ;_ lambda
          (read (strcat "(" (VL-STRING-TRANSLATE "," " " s) ")"))
        (pars (read-line f) f f1)
      ) ;_ progn
        (close f)
        (close f1)
      ) ;_ progn
    ) ;_ if
  ) ;_ defun
  (defun min_max (mi ma l f)
    (if l
      (if (< (car l) mi)
        (min_max (car l) ma (cdr l) f)
        (if (> (car l) ma)
          (min_max mi (car l) (cdr l) f)
          (min_max mi ma (cdr l) f)
        ) ;_ if
      ) ;_ if
      (write-line (strcat (itoa mi) " " (itoa ma)) f)
    ) ;_ if
  ) ;_ defun
  (pars (read-line (setq f (open "D:\\numbers.csv" "R"))) f (open "D:\\result.csv" "W"))
  (princ
    (strcat
      "Process took "
      " seconds."
    ) ;_ strcat
  ) ;_ princ
) ;_ defun
(defun c:test_2 (/ f f1 timer)
  ;;(c:test_2)
  ;; ElpanovEvgeniy
  (defun pars (s f)
    (if s
      (cons (read (strcat "(" (VL-STRING-TRANSLATE "," " " s) ")"))
            (pars (read-line f) f)
      ) ;_ cons
      (close f)
    ) ;_ if
  ) ;_ defun
    (if l
      (if (< (car l) mi)
        (if (> (car l) ma)
        ) ;_ if
      ) ;_ if
    ) ;_ if
  ) ;_ defun
  (setq f1 (open "D:\\numbers.csv" "R"))
  (setq f (open "D:\\result.csv" "W"))
  (foreach l (pars (read-line f1) f1)
      (min_max (car l) (cadr l) (cddr l) f)
      (min_max (cadr l) (car l) (cddr l) f)
    ) ;_ if
  ) ;_ foreach
  (close f)
  (princ
    (strcat
      "Process took "
      " seconds."
    ) ;_ strcat
  ) ;_ princ
) ;_ defun
(defun c:max-min (/ file1 file2 lin linlist max1 min1 timer)
  ;;(c:max-min)
  ;;Jeff_M
  (defun Split (str / i j lst)
    (setq i 0)
    (while (setq j (vl-string-search "," str i))
      (setq lst (cons (substr str (1+ i) (- j i)) lst)
            i   (1+ j)
      ) ;_ setq
    ) ;_ while
    (reverse (cons (substr str (1+ i)) lst))
  ) ;_ defun
;;;main function
    (setq
      file1 (open "D:\\numbers.csv" "R")
    ) ;_ setq
       (setq file2
              (open "D:\\results.csv"
                    "W"
              ) ;_ open
       ) ;_ setq
       (while (setq lin (read-line file1))
         (setq linlist (mapcar 'atoi (split lin)))
         (setq min1 (apply 'min linlist)
               max1 (apply 'max linlist)
         ) ;_ setq
         (write-line (strcat (itoa max1) "," (itoa min1)) file2)
       ) ;_ while
       (close file1)
       (close file2)
       (princ
                 " seconds."
         ) ;_ strcat
       ) ;_ princ
     ) ;_ progn
  ) ;_ if
) ;_ defun
(defun c:minmax (/ #HI #LOW F1 L1 LINEM NEWFILE TIMER)
  ;;(c:minmax)
  ;; Andrea
                 "r"
           ) ;_ open
        l1 (read-line f1)
  ) ;_ setq
  (if l1
    (setq newfile (open "D:\\result.txt" "w"))
  ) ;_ if
  (while l1
    ) ;_ setq
  ) ;_ while
  (close f1)
  (close newfile)
  (princ
                 " seconds."
         ) ;_ strcat
) ;_ defun
(defun c:test (/ FILEBASE FILEDATA FILENAME HANDLE LST PATH STREAM)
  ;; CAB
  ;;(c:test)
  (defun sparser1 (str delim / ptr lst)
    ;;  parser by CAB
    (while (setq ptr (vl-string-search delim str))
      (setq lst (cons (substr str 1 ptr) lst))
      (setq str (substr str (+ ptr 2)))
    ) ;_ while
    (reverse (cons str lst))
  ) ;_ defun
      (setq filename "D:\\numbers.csv")
      (setq handle (open filename "r"))
    ) ;_ and
       (while (setq stream (read-line handle))
         (setq FileData (cons stream FileData))
       )                                ; while
       (close handle)
     ) ;_ progn
  ) ;_ if
  (if FileData
      (setq path     (vl-filename-directory filename)
            filebase (vl-filename-base filename)
            handle   (open (strcat path "\\" filebase "-out.csv") "w")
      ) ;_ setq
      (mapcar
        (function
          (lambda (x)
            (setq lst
                   (mapcar
                     (function
                       (lambda (y)
                         (atoi y)
                       ) ;_ lambda
                     ) ;_ function
                     (sparser1 x ",")
                   ) ;_ mapcar
            ) ;_ setq
            (princ (apply 'max lst) handle)
            (princ "-" handle)
            (princ (apply 'min lst) handle)
            (princ "\n" handle)
          ) ;_ lambda
        ) ;_ function
        FileData
      ) ;_ mapcar
      (close handle)
      (princ
                " seconds."
        ) ;_ strcat
      ) ;_ princ
    ) ;_ progn
  ) ;_ if
) ;_ defun
Check:
(c:test) ;; CAB
(c:minmax) ;; Andrea
(c:max-min) ;;Jeff_M
(c:test_2) ;; ElpanovEvgeniy
(c:test_1) ;; ElpanovEvgeniy
 VLX-Application packed D:/Work/Project/lib/test/test.VLX
_$
Process took 0.83 seconds.
 Process took 1.67 seconds.
 Process took 0.84 seconds.
 Process took 0.469 seconds.
 Process took 0.5 seconds.
check 2
_$
Process took 0.81 seconds.
 Process took 1.66 seconds.
 Process took 0.88 seconds.
check 3
_$
 Process took 1.64 seconds.
 Process took 0.453 seconds.
« Reply #22 on: December 02, 2006, 07:39:11 AM »
Evgeniy,
Very fast, I see that vl-string-translate makes a huge deference.
I revised mine & cut the time here in half.
;;  CAB Revised
(defun c:test2 (/ FILEBASE FILEDATA FILENAME HANDLE LST PATH STREAM
               sparser)
      (setq filename (findfile "numbers.csv"))
       ) ; while
       (close handle)
  (if FileData
      (mapcar
        (function
          (lambda (x)
            (setq lst (read (strcat "(" (vl-string-translate "," " " x) ")")))
            (princ "-" handle)
            (princ "\n" handle)
        FileData
      (close handle)
                     " seconds."
« Reply #23 on: December 02, 2006, 07:53:26 AM »
Evgeniy,
Looking more at your routine I suspect the recursive min_max may be faster than
(apply 'max lst) but I haven't tested that. 8-)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #24 on: December 02, 2006, 08:03:03 AM »
(c:test2) ;; CAB Revised
(c:test) ;; CAB
_$
Process took 0.44 seconds.
 Process took 0.86 seconds.
 Process took 1.81 seconds.
 Process took 0.8 seconds.
« Reply #25 on: December 02, 2006, 08:13:52 AM »
Thanks you Sir.
My test were similar, relatively speaking.
Your fastest version I suspect must be that you simulated the APPLY MIN MAX with your
faster code. Very nice! :-)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #26 on: December 02, 2006, 08:42:23 AM »
new version...
(defun c:test_3 (/ f f1 timer)
  ;;(c:test_2)
  ;; ElpanovEvgeniy
  (defun pars (s f)
    (if s
      ) ;_ cons
      (close f)
    ) ;_ if
  ) ;_ defun
    (if l
      (if (< (car l) mi)
        (if (> (car l) ma)
        ) ;_ if
      ) ;_ if
      (strcat (itoa mi) " " (itoa ma) "\n")
    ) ;_ if
  ) ;_ defun
  (princ
    (apply
      (function strcat)
      (mapcar
        (function
          (lambda (l)
            ) ;_ if
          ) ;_ lambda
        ) ;_ function
      ) ;_ mapcar
    ) ;_ apply
    f
  ) ;_ princ
  (close f)
  (princ
    (strcat
      "Process took "
      " seconds."
    ) ;_ strcat
  ) ;_ princ
) ;_ defun
Check:
(c:test_3) ;; ElpanovEvgeniy
_$
Process took 0.47 seconds.
 Process took 0.406 seconds.
« Reply #27 on: December 02, 2006, 08:50:21 AM »
You guys never fail to amaze me! :-)
« Reply #28 on: December 02, 2006, 09:02:16 AM »
Evgeniy you're about the break the 'Sound Barrier'  8-)
Andrea
« Reply #29 on: December 02, 2006, 09:08:12 AM »
wOo !...
i'm the slowest... ^-^
do i win something ?... :-D
Keep smile...
