Author Topic: ( Challenge ) Just curious  (Read 18554 times)
« on: December 01, 2006, 02:05:26 PM »
I was wondering why none of you LISP masters participated in the latest challenge?
[ http://www.theswamp.org/index.php?topic=13679.0 ] HI LOW
Re: ( Challenge ) Just curious
« Reply #1 on: December 01, 2006, 02:45:13 PM »
No reason. Note, subs not included.
Command: hilow
 Elasped time 2.687 seconds.
(defun c:HiLow (/ File Opened TextLine TextList NumList Timer NewOpened NewFile)
  (setq File (getfiled "" "" "csv" 4))
  (setq Opened (open File "r"))
  (setq NewFile (strcat (vl-filename-directory File) "\\Returned.csv"))
  (setq NewOpened (open NewFile "w"))
  (setq Timer (StartTimer))
  (while (setq TextLine (read-line Opened))
   (setq TextList (StrParse TextLine ","))
   (setq NumList (mapcar '(lambda (x) (cons (distof x) x)) TextList))
   (setq NumList (vl-sort NumList '(lambda (a b) (< (car a) (car b)))))
;   (prompt (strcat "\n " (cdar NumList) " - " (cdr (last NumList))))
   (write-line (strcat (cdar NumList) "," (cdr (last NumList))) NewOpened)
  (close Opened)
  (close NewOpened)
  (prompt (EndTimer Timer))
13   922
133   992
337   980
39   869
76   944
149   877
87   959
82   777
235   980
307   834
Edit:  Forgot to add that I'm no master.
« Last Edit: December 01, 2006, 02:46:40 PM by T.Willey »
« Reply #2 on: December 01, 2006, 02:51:49 PM »
I'll admit that I whipped up one that I was going to post but Acad crashed doing something else (real work) before I saved it. I just never got back to re-writing it (forgot about it, actually, after trying to find what I did to crash), plus it was far slower than what the others came up with....but still faster than Tim's :-P at ~1.5 seconds. I'll see if I can duplicate it during lunch today (starts in about 10 minutes).
« Reply #3 on: December 01, 2006, 02:59:21 PM »
I didn't realize it was open to all languages.
Me no speak C++
« Reply #4 on: December 01, 2006, 03:00:05 PM »
Man the love is gone from this place I see.  :oops: :cry:
I would love to see how you do it Jeff.
« Reply #5 on: December 01, 2006, 03:12:46 PM »
Jeff that sounds a lot like "My dog ate my home work" .  :lmao:
« Reply #6 on: December 01, 2006, 03:20:56 PM »
x2  :angel:
« Reply #7 on: December 01, 2006, 03:33:31 PM »
Heh, I dunno what I'm doing differently but now I can only achieve a time of about 3.5 seconds :|
(defun c:max-min (/ file1 file2 lin linlist max1 min1 timer)
  (defun Split (str / i j lst)
    (setq i 0)
    (while (setq j (vl-string-search "," str i))
      (setq lst (cons (substr str (1+ i)(- j i)) lst)
    i (1+ j)
    (reverse (cons (substr str (1+ i)) lst))
  ;;;main function
  (setq timer (getvar "millisecs"))
  (if (setq file1 (open "C:\\Base Maps\\Jeffs Test Files\\junk\\numbers.csv" "R"))
      (setq file2 (open "C:\\Base Maps\\Jeffs Test Files\\junk\\results.csv" "W"))
      (while (setq lin (read-line file1))
(setq linlist (mapcar 'atoi (split lin)))
(setq min1 (apply 'min linlist)
      max1 (apply 'max linlist)
(write-line (strcat (itoa max1) "," (itoa min1)) file2)
      (close file1)
      (close file2)
      (princ (strcat "Process took " (rtos (/ (- (getvar "millisecs") timer) 1000.0) 2 2) " seconds."))
« Reply #8 on: December 01, 2006, 03:37:19 PM »
No worries, Tim, there's plenty of love to go around....it IS that time of year :-)
I'm beginning to think I'd love to see how I did it, too. :|
« Reply #9 on: December 01, 2006, 03:55:54 PM »
Me no speak C++
Well if I posted the challenge here then the C/C++/C#, Python and VB folks would feel left out! :-)
Unless otherwise noted, all challenges are open to all languages.
« Reply #10 on: December 01, 2006, 04:12:26 PM »
Times:
Command: test
Process took 1.97 seconds.
Command:
Command: test
Process took 2.01 seconds.
Command:
Command: test
Command:
Command: test
Process took 2.00 seconds.
Command:
Command: test
Command:
Command: test
Command:
Command: test
Process took 2.02 seconds.
Command:
Command: test
Routines will need to be compared  on one computer for the times to mean anything.
1.2Ghz here
(defun c:test (/ FILEBASE FILEDATA FILENAME HANDLE LST PATH STREAM)
      (setq filename (findfile "numbers.csv"))
      (setq handle (open filename "r"))
       (while (setq stream (read-line handle))
         (setq FileData (cons stream FileData))
       ) ; while
       (close handle)
  (if FileData
      (setq path     (vl-filename-directory filename)
            filebase (vl-filename-base filename)
            handle   (open (strcat path "\\" filebase "-out.csv") "w")
      (mapcar
        (function
          (lambda (x)
            (setq lst
                   (mapcar
                     (function
                       (lambda (y)
                         (atoi y)
                     (sparser1 x ",")
            (princ (apply 'max lst) handle)
            (princ "-" handle)
            (princ (apply 'min lst) handle)
            (princ "\n" handle)
        FileData
      (close handle)
                     " seconds."
;;  parser by CAB
(defun sparser1 (str delim / ptr lst)
  (while (setq ptr (vl-string-search delim str))
    (setq lst (cons (substr str 1 ptr) lst))
    (setq str (substr str (+ ptr 2)))
  (reverse (cons str lst))
« Last Edit: December 01, 2006, 04:15:12 PM by CAB »
« Reply #11 on: December 01, 2006, 04:14:18 PM »
Now you know how we felt.
Just kidding  :-D
« Reply #12 on: December 01, 2006, 04:51:46 PM »
1.2Ghz here
I guess I can do that.
Command: test
Process took 1.11 seconds.
Command:
Command:
TEST Process took .91 seconds.
Command:
Command:
TEST Process took .92 seconds.
Command:
Command:
Edit: vvv
I added a reverse to your function Alan (so the order would be the same as the first csv file), and reran it.
Command: test
Command:
Command:
TEST Process took .95 seconds.
Command:
Command:
« Last Edit: December 01, 2006, 04:59:01 PM by T.Willey »
« Reply #13 on: December 01, 2006, 05:00:25 PM »
Hmmm, evidently the amount of RAM in use also plays a role in the speed of execution. When I was testing my code at lunch I was in R2002 but I had C3D2007 open (among numerous other smaller programs), too. I closed the C3D about 10 minutes ago and tried CAB's and it came in at:
Command: test
Process took 2.52 seconds.
I then re-ran mine and got this:
Command: max-min
Process took 2.14 seconds.
That's a HUGE difference from the 3.5-3.6 seconds I was getting earlier.....but it's also still a far cry from the sub 1 second performance of the C++/C#/Python crowd.
Oh, the other smaller programs in use during all tests.....
outlookExpress6, Firefox 1.5.0.8, WinExplorer x2, Map5.
Computer:
Toshiba Laptop
P4@2.8 ghz, 1gb RAM
Holy Katz, Tim! Is my laptop really that slow?. <grumble.wav>
« Reply #14 on: December 01, 2006, 05:04:12 PM »
Mark, I think you need to go wakeup those VBA guys too!  :police:
