Author Topic: Building ArxDbg for Ac2007  (Read 2583 times)
« on: November 30, 2006, 11:19:39 PM »
Wondering if someone can help me due to CPP ignorance
With VS2005 I've just Built the ARXDbg Solution from the SDK.
The Build reported sucess but I have these warnings when doing a Debug Build.
The Release Build is faultless ..
Can someone illuminate the actual cause of these warnings < in Laymans language please>
/// kwb
--> Donate to theSwamp<--
It's Alive!
  • BricsCAD
  • AKA Daniel
Re: Building ArxDbg for Ac2007
« Reply #1 on: November 30, 2006, 11:36:42 PM »
I get the same thing.
I found these links
http://discussion.autodesk.com/thread.jspa?messageID=4193222
http://discussion.autodesk.com/thread.jspa?messageID=387905
edit
Putting this option /ignore:4099  project properties > linker > command line suppressed the warning also
« Last Edit: November 30, 2006, 11:42:53 PM by Danielm103 »
MickD
  • !false...it's funny 'cause it's true!
« Reply #2 on: November 30, 2006, 11:39:06 PM »
When they built the arx lib's they would have these .pdb files generated if 'switched' on (see below). Looking at my sdk for 2006 the \lib folder does not contain them so I wouldn't worry about them as long as you can debug your code.
hth,
Mick.
A programmer's wife tells him, "Run to the store and pick up a loaf of bread. If they have eggs, get a dozen."
The programmer comes home with 12 loaves of bread.
« Reply #3 on: November 30, 2006, 11:46:08 PM »
Thanks guys.
LE
« Reply #4 on: December 01, 2006, 12:05:37 AM »
I have the build ArxDbgd17.arx - in case you needed
Let me know Kerry
le
LE
« Reply #5 on: December 01, 2006, 12:07:43 AM »
/// kwb
Those lib's not found are not harmful... you can ignore them...
« Reply #6 on: December 01, 2006, 12:11:11 AM »
Let me know Kerry
le
I've Built them sucessfully Luis, as I mentioned.
Just trying to find the cause of the warning, is all.
ta
kwb
