Author Topic: Highlight a nested block  (Read 10998 times)
Draftek
Re: Highlight a nested block
« Reply #15 on: December 14, 2006, 08:08:44 AM »
uh, sorry I didn't post that I got the solution from them (ADN).
My bad.
Too busy these days..
LE
« Reply #16 on: December 14, 2006, 10:42:49 AM »
... ps he thinks I'm a lady, but I've had worse said  ....
It got fix now... Kerry
Kean
« Reply #17 on: December 14, 2006, 11:59:37 AM »
I'll go ahead and post the second response, as well, once I've tidied it up a little (tomorrow, I expect).
My apologies, Kerry: as I was growing up, my neighbour had a daughter called Kerry, so that must be why my fingers automatically assumed you were female. Although I've certainly had male friends with the same first name... :roll:
Anyways - as LE says the post has been fixed...
Kean
Chuck Gabriel
« Reply #18 on: December 14, 2006, 12:23:23 PM »
Welcome aboard Kean.
« Reply #19 on: December 14, 2006, 04:01:40 PM »
Welcome to theSwamp Kean.
Thanks for posting both solutions. They are both interesting code and solve a real issue.
don't be fussed about the he, she, it thing :-)
« Reply #20 on: December 14, 2006, 04:03:30 PM »
My bad.
Just for interest, it may be good to compare solutions ....
Kean
« Reply #21 on: December 15, 2006, 07:21:15 AM »
I've just posted the block highlighting code to my blog:
http://through-the-interface.typepad.com/through_the_interface/2006/12/highlighting_a_.html
Regards,
Kean
Draftek
« Reply #22 on: December 15, 2006, 08:12:39 AM »
Thanks.
