Have been so busy at the new job / life haven't been able to participate here at all <insert crying icon here>. All I can say is "I sincerely wish you all well" and "here is some code / food for thought" in a <lame> attempt to make up for lost time. No time to explain how to use, the in-line comments will have to suffice.
Provided as is, complete with warts, pimples and errors -- no warranties stated or impied. In other words, use at your own risk!
(defun _OdbxReport ( filelist reportname overwrite foo / handle document result )
;; Written by Michael Puckett
;; In short this function is a convenience wrapper. For a given
;; filelist, reportname, overwrite toggle and arbitrary function
;; 'Foo' it will, if possible, cycle through all of the drawings in
;; filelist and apply function 'Foo to said drawings.
;; Arguments:
;; filelist : A list of path qualified files.
;; reportname : A path qualified file which will be opened for
;; output, writing over any original contents if
;; overwrite argument is non nil, otherwise
;; appending new data to existing.
;; overwrite : As noted, indicates whther the report is
;; overwritten or appended.
;; foo : Arbitrary function which must have this
;; signature:
;; (defun foo ( docname document handle ) ... )
;; Where:
;; docname : A string, the name of the
;; document.
;; document : An objectdbx document.
;; handle : A file handle opened for
;; output.
;; For example, 'Foo' might be as simple as:
;; (lambda ( docname document handle )
;; (princ
;; (strcat
;; docname
;; " has "
;; (itoa
;; (vlax-get
;; (vlax-get
;; document
;; 'RegisteredApplications
;; 'Count
;; " appid(s).\n"
;; handle
;; What 'Foo' actually does with the objectdbx document or the
;; handle this function cares not, its sole responsibility is to:
;; 1. Open the report file for output, either overwrite or
;; append.
;; 2. Cycle through all files:
;; 2.1 Open the file via objectdbx.
;; 2.2 Pass document etc. to function 'Foo'.
;; 2.3 Close the objectdbx file.
;; 3. Close the report file.
;; reporting any errors thrown trying to open the report file,
;; opening files via objectdbx, or unhandled errors thrown by
;; function 'Foo'. Typically 'Foo' will interogate the objectdbx
;; document and write data to the handle.
;; "But" you say, "it seems redundant, passing the document name
;; when one could just use (vla-get-name document)".
;; Ahhhh, but if a temporary copy of the document is created by
;; the (_OdbxOpen ...) function the name reported will be wrong. In
;; other words, if 'Foo' needs to report the original document name
;; it should use the docname argument rather than querying the
;; document for its name, ergo the docname requirement. If the
;; actual document name is desired you can use the afore mentioned
;; vla-get-name function. If necessary you can use the supplied
;; function _OdbxIsTempCopy function to determine if the document
;; is not the original.
;; What's the point of all this again?
;; Typically function 'Foo' will interogate the document and write
;; information to the data file represented by the handle. Could be
;; block attribute data, could be some other rivoting data like
;; AutoPlant component IDs, who knows. This function provides easy
;; access to previous authored functions, like the _OdbxOpen and
;; _OdbxClose functions to make easy the frequent exercise of using
;; ObjectDBX to interogate multiple files. No point in penning the
;; same scafolding again and again.
( (setq handle (open reportname (if overwrite "w" "a")))
(foreach docname filelist
( (setq document (_OdbxOpen docname t))
(vl-catch-all-error-p
(setq result
(vl-catch-all-apply
'(lambda ( )
(foo
docname
document
handle
(princ
(strcat
"(Foo docname document handle)"
" threw this error: <"
(vl-catch-all-error-message result)
">\n"
(_OdbxClose document)
( (princ
(strcat
"Could not open <"
docname
"> with ObjectDBX.\n"
(close handle)
( (princ
(strcat
"Could not open <"
reportname
"> for output.\n"
(defun c:Example ( )
(_OdbxReport
;; filelist
"x:\\SomePath\\SomeName1.dwg"
"x:\\SomePath\\SomeName2.dwg"
"x:\\SomePath\\SomeName3.dwg"
;; reportname
"c:\\MyReportName.txt"
;; overwrite
t
;; foo
(princ
(strcat
docname
" has "
(itoa
(vlax-get
(vlax-get
document
'Count
" appid(s).\n"
handle
And the supporting cast ...(defun _OdbxOpen ( drawingname tempflag / foo exists odbxdoc tempfile result )
;; Open the document via ObjectDBX if possible (trap any errors).
;; If the file cannot be opened directly AND the tempflag is non
;; nil try to open a temporary copy (flagging it as a copy).
( (and
(defun foo ( odbxdoc drawingname )
(null
(vl-catch-all-apply
'(lambda ( )
(vla-open
odbxdoc
drawingname
(setq exists (_Exists drawingname))
(setq odbxdoc (_OdbxGetInterface))
(foo odbxdoc drawingname)
;; File opened no problem.
(setq result odbxdoc)
(and
exists
odbxdoc
;; Assumption: File exists in a read-only directory,
;; (can't make associated dwl file) try make and use
;; a temporary copy.
(setq tempfile (_MakeTempFileCopy drawingname))
(foo odbxdoc tempfile)
;; Flag the file as being a temp by adding a main dict
;; entry named "OdbxTempCopy".
;; See companion functions --
;; _OdbxIsTempCopy
;; _OdbxDeleteIfTempCopy
(vl-catch-all-apply
'(lambda ( )
(vla-add
(vla-get-dictionaries odbxdoc)
"OdbxTempCopy"
( odbxdoc
(vlax-release-object odbxdoc)
result
(defun _OdbxClose ( document / filename )
;; Close the objectdbx document. If it was a temporary copy made by
;; _OdbxOpen try to delete it.
;; _OdbxOpen
;; _OdbxIsTempCopy
(if (_OdbxIsTempCopy document)
(setq filename (vla-get-name document))
(vl-catch-all-apply
'(lambda ( )
(vlax-release-object document)
(if filename
(vl-catch-all-apply
'(lambda ( )
(vl-file-delete filename)
(defun _OdbxGetInterface ( / version )
;; If possible create an instance of the ObjectDBX interface.
;; If I recall correctly Luis Esquivel helped me refine this way
;; back in the day on the Autodesk forums. Others too have
;; contributed to the collective objectdbx knowledge, folks like
;; Tony Tanzillo, who was the first to publically share any info
;; about said topic and who we are all indebted to.
(if (_OdbxGetCLSID)
(vla-getinterfaceobject
(vlax-get-acad-object)
(apply 'strcat
(cons "ObjectDBX.AxDbDocument"
(if (/= 15 (setq version (atoi (getvar "acadver"))))
(list "." (itoa version))
(defun _OdbxGetCLSID ( / key version dll )
;; Get the ObjectDBX CLSID so callers may attemp to create an
;; objectdbx interface. If necessary register the dll (was required
;; for early versions of AutoCAD, like 2000 IIRC.
( (vl-registry-read
(setq key
(strcat "HKEY_CLASSES_ROOT\\ObjectDBX.AxDbDocument"
(if (eq 15 (setq version (atoi (getvar "acadver"))))
"\\CLSID"
(strcat "." (itoa version) "\\CLSID")
( (and
(setq dll
(findfile
(strcat
"AxDb"
(itoa version)
".dll"
(_RegSvr32 dll)
(vl-registry-read key)
(defun _OdbxIsTempCopy ( document / result )
;; Determine if the document is a temporary copy that had been made
;; via the _OdbxOpen function.
;; _OdbxOpen
;; _OdbxClose
(vl-catch-all-apply
'(lambda ( )
(setq result
(not
(null
(vla-item
(vla-get-dictionaries document)
"OdbxTempCopy"
result
(defun _RegSvr32 ( dll / cmd path match )
;; If possible register the specified dll.
(vl-some
'(lambda (x) (startapp x (strcat "\"" dll "\" /s")))
(list
(setq cmd "regsvr32.exe")
(strcat
(setq path (getenv "WinDir"))
"\\System\\"
cmd
(strcat path "\\System32\\" cmd)
(setq match
(strcat
(strcase (vl-filename-base dll))
(vl-some
'(lambda (x) (wcmatch (strcase x) match))
(vl-registry-descendents "HKEY_CLASSES_ROOT")
(defun _MakeTempFileCopy ( filename / result )
;; If possible make a copy of the specified file in the temp
;; folder.
(and
(findfile filename)
(vl-file-copy
filename
(setq result
(vl-filename-mktemp
nil
nil
(vl-filename-base filename)
nil
result
(defun _Exists ( filename / handle )
;; Return t if the file exists. Note that this differs from
;; findfile function which will search the AutoCAD support path.
;; This function merely reports whether a file exists as expressed.
(and
(setq handle (open filename "r"))
(null (close handle))
Kind regards all!
