Author Topic: Availability of ADODB.Command  (Read 3061 times)
« on: November 27, 2006, 07:08:12 PM »
I want to determine if the code following works if MS Office is not installed.
I'm particularly interested in ADO COM at this time.
In an XP install I believe MDAC is installed which I think should satisfy this test ..
If my assumption is whacky, I'll have to try another route.
This code just does Registry reads ...
... please post results
(DEFUN c:test ()
    (AND (SETQ _ADODLLCLSID (VL-REGISTRY-READ
                                "HKEY_CLASSES_ROOT\\ADODB.Command\\CLSID"
         (SETQ
             _ADODLLPath (VL-REGISTRY-READ (STRCAT "HKEY_CLASSES_ROOT\\CLSID\\"
                                                   _ADODLLCLSID
                                                   "\\InProcServer32"
         (SETQ _ADODLLPath_Qualified (FINDFILE _ADODLLPath))
    (TERPRI)
    (princ _ADODLLCLSID)
    (TERPRI)
    (princ _ADODLLPath)
    (TERPRI)
    (princ _ADODLLPath_Qualified)
kwb
LE
Re: Availability of ADODB.Command
« Reply #1 on: November 27, 2006, 07:21:36 PM »
Si funciona Kerry, aqui estan los resultados (aqui no esta instalado nada de Office)
It works Kerry, below are the results (I do not have any Office installed here)
Command: test
{00000507-0000-0010-8000-00AA006D2EA4}
C:\Program Files\Common Files\System\ado\msado15.dll
Espero te sirva
HTH
« Reply #2 on: November 27, 2006, 07:26:56 PM »
That 'serves me' well Luis, Thanks ....
Would like a couple more confirmations though .... just to be positive.
kwb
« Reply #3 on: November 27, 2006, 07:28:41 PM »
Mine is the same as Luis's.  But I think I have office installed, I mean I have all the programs.
« Reply #4 on: November 28, 2006, 12:06:20 AM »
Anyone else without Office/Access installed in Win XP ??
It's Alive!
  • Retired
  • AKA Daniel
« Reply #5 on: November 28, 2006, 12:12:53 AM »
I do, but there is no cad on it. Is there something I can look for manually?
edit
the brand new install XP SP2 has the file  C:\Program Files\Common Files\System\ado\msado15.dll
nothing has been installed on the machine but the os.
« Last Edit: November 28, 2006, 12:18:01 AM by Danielm103 »
« Reply #6 on: November 28, 2006, 12:30:51 AM »
PERFECT !! Thanks Daniel ..
