I want to determine if the code following works if MS Office is not installed.
I'm particularly interested in ADO COM at this time.
In an XP install I believe MDAC is installed which I think should satisfy this test ..
If my assumption is whacky, I'll have to try another route.
This code just does Registry reads ...
... please post results
(DEFUN c:test ()
(AND (SETQ _ADODLLCLSID (VL-REGISTRY-READ
"HKEY_CLASSES_ROOT\\ADODB.Command\\CLSID"
(SETQ
_ADODLLPath (VL-REGISTRY-READ (STRCAT "HKEY_CLASSES_ROOT\\CLSID\\"
_ADODLLCLSID
"\\InProcServer32"
(SETQ _ADODLLPath_Qualified (FINDFILE _ADODLLPath))
(TERPRI)
(princ _ADODLLCLSID)
(TERPRI)
(princ _ADODLLPath)
(TERPRI)
(princ _ADODLLPath_Qualified)
kwb
