Author Topic: Change MText to a single color  (Read 13061 times)
LE
Re: Change MText to a single color
« Reply #15 on: November 29, 2006, 12:35:24 PM »
Well after some attempts and by trying to assimilate how to handle string's in C#, I came up with a code that works, it may help someone in a future coding, I think.
private void OnClick_RemoveColor(object sender, EventArgs e)
    //Editor ed = acadApp.DocumentManager.MdiActiveDocument.Editor;
    string txtstr = textBox1.Text;
    char[] s = txtstr.ToCharArray();
    int cont = 0, flag = 0;
    string txt1 = "", let = "";
    for (int j = 0; j < txtstr.Length; j++)
        try
            let = s[cont].ToString();
            if (let == "\\")
                if (s[(cont + 1)].ToString() == "C" || s[(cont + 1)].ToString() == "c")
                    int i = (cont + 2);
                    while (s[i].ToString() != ";")
                        i = i + 1;
                    // remove true and book colors
                    if (s[i + 1].ToString() == "\\" && s[i + 2].ToString() == "c")
                        i = i + 2;
                            i = i + 1;
                    txt1 = txt1 + s[i + 1].ToString();
                    cont = i + 2;
                else
                    flag = 1;
            else // color format found
                txt1 = txt1 + let;
                // remove the color blocks
                int found;
                found = txt1.IndexOf("{");
                if (found >= 0)
                    txt1 = txt1.Remove(found, 1);
                found = txt1.IndexOf("}");
                if (found >= 0)
                cont = 1 + cont;
            // no color format found
            if (flag == 1)
                txt1 = txt1 + let;
                cont = 1 + cont;
                flag = 0;
        catch
            //ed.WriteMessage("Error");
    textBox1.Text = txt1; // change the contents
OK I have here three different code flavours to do a same task, using C++, ObjectARX, AutoLISP, VLISP & C#
With the exception of Glenn, I see a lot of views, but zero participation at all, I would like to know why, so in my future topics, I can post something of interest.
EndOfTopic
« Last Edit: November 29, 2006, 12:39:25 PM by LE »
« Reply #16 on: November 29, 2006, 12:42:41 PM »
I look to see if I can understand more advance languages, and to see what I can learn.  I appreciate all the code you post, as I learn something each time, especially if it's in a language I don't know, which is all but Lisp.  Thanks for all the code you post Luis.
Glenn R
  • What idiot child of married cousins wrote this?!
« Reply #17 on: November 29, 2006, 06:17:01 PM »
Luis,
You'll see in the code below, where I changed some of yours to give you a different way of looking at it, syntactically as least...too tired for anything else at the moment.
The main change was to treat the textbox string as an array of char's and process that:
// char[ ] s = txtstr.ToCharArray();
string txt1 = ""/*, let = ""*/;
try
//let = s[cont].ToString();
char let = txtstr[cont];
// if (let == "\\")
if (let == '\\')
//if (s[(cont + 1)].ToString() == "C" || s[(cont + 1)].ToString() == "c")
if (char.ToUpper(txtstr[cont + 1]) == 'C')
int i = (cont + 2);
i = i + 1;
while (txtstr[i] != ';')
i++;
//if (s[i + 1].ToString() == "\\" && s[i + 2].ToString() == "c")
if (txtstr[i + 1] == '\\' && txtstr[i + 2] == 'c')
i = i + 2;
i = i + 1;
i++;
//txt1 = txt1 + s[i + 1].ToString();
txt1 += txt1 + txtstr[i + 1];
cont = i + 2;
else
flag = 1;
txt1 = txt1 + let;
int found;
if (found >= 0)
if (found >= 0)
cont = 1 + cont;
if (flag == 1)
txt1 = txt1 + let;
cont = 1 + cont;
flag = 0;
catch
Cheers,
Glenn.
Me
« Reply #18 on: November 29, 2006, 06:31:00 PM »
Don't worry yourself about it Luis,  just keep on posting, like the rest of us.
Someone will tell you if they don't like your posts,  I'm sure  :lol:   .. and some of us haven't had time to read them.
--> Donate to theSwamp<--
LE
« Reply #19 on: November 29, 2006, 06:36:44 PM »
Luis,
Cheers,
Glenn.
Glenn;
Got it, I was trying to implement that first.... but got lost... I see it now - they are more hoops in C# but start to like it.
Thank you.
« Last Edit: November 29, 2006, 06:47:15 PM by LE »
LE
« Reply #20 on: November 29, 2006, 06:42:10 PM »
He he.... Thanks.
I will post the project in the C# forum, at least just to have a new post and get more points..... yeah!!!!
Glenn R
« Reply #21 on: November 29, 2006, 06:49:27 PM »
A lot LESS hoops compared to say C++ if you ask me Luis ;)
Me
« Reply #22 on: November 29, 2006, 06:55:10 PM »
Yeah,   .... posting there I'm more likely to at least see it,  ... just don't lost it in one of the "social" furums, some of us would never see it   :-)
LE
« Reply #23 on: November 29, 2006, 07:10:19 PM »
Luis,
OK.... I copied (without checking your code) in my class, and is giving undesired results... I'll check that later at home, I know you did that on the fly... and will move the MtextEditor project to the C# forum...
Thanks.
Glenn R
« Reply #24 on: November 29, 2006, 07:15:54 PM »
It definately was on the fly Luis, sorry about that. It was more intended to give you another idea/way of looking at it is all.
Cheers,
Glenn.
Me
LE
« Reply #25 on: November 29, 2006, 07:18:02 PM »
Yes I know  :-)
« Reply #26 on: November 29, 2006, 07:22:14 PM »
Luis, The Mtext class has an  mtext.ExplodeFragments method  ... can you us that ?
LE
« Reply #27 on: November 29, 2006, 07:27:43 PM »
Yes... was the first one I tried.... and the idea is to show different ways... (well, when I do not have nothing else to do - lately it has been a lot, that's how I waste my time... in case you know if a company needs some help doing some janitorial services, let me know, I have Friday and Saturday open.... )
http://www.theswamp.org/index.php?topic=13650.msg164984#msg164984
« Last Edit: November 29, 2006, 07:31:30 PM by LE »
« Reply #28 on: November 29, 2006, 07:37:21 PM »
ok, didn't really try to digest the CPP earlier ...
Have you tried the ExplodeFragments in C# ?
LE
« Reply #29 on: November 29, 2006, 07:41:40 PM »
nope.... but I would see if I can, later at home... it must be basically the same as my code in ARX... well it is just a guess.
Does anyone knows if exist a software to port C++ to C# (I know there is one from C# to C++).... just curios.
I would like to port my code of GBPoly... just to waste my time... as normal.... he he
