Author Topic: Change Plot to File location  (Read 2098 times)
Guest
« on: November 21, 2006, 09:41:11 AM »
I would like to change the default PLOT TO FILE location (on the Plot & Publish tab of the Options dialog box), but I don't know what, if any, the variable name is.  Also, I would like to ensure that the PUBLISHING check box is checked.
Anyone know how to change this programmatically??!?
rkmcswain
Re: Change Plot to File location
« Reply #1 on: November 21, 2006, 09:52:10 AM »
Example:
(vla-put-DefaultPlotToFilePath (vla-get-Output (vla-get-Preferences (vlax-get-acad-object))) "c:\\")
Are you talking about "background processing"?
This is the BACKGROUNDPLOT system variable.
Guest
« Reply #2 on: November 21, 2006, 09:59:27 AM »
Nice.
Thanks!  (so many sysvars.... I forgot about the bgplot variable).
« Reply #3 on: November 21, 2006, 10:53:30 AM »
You can also use:
(setenv "PlotToFilePath" "C:/")
Ron
