Author Topic: Text in Dimensions  (Read 2039 times)
Matersammichman
Text in Dimensions
« on: November 17, 2006, 01:43:06 PM »
How would you extract the Bounding Box information of Text contained in a Dimension? (Not the Bounding Box of the Dimension itself).
Re: Text in Dimensions
« Reply #1 on: November 18, 2006, 12:24:38 AM »
You would need to do a couple of things since the text from a dimension is represented by <> plus the overrides if they exist.
You would need to extract the current text of the dimension (i.e. any text overrides) then the text size and style, plus the dimension length, formatted into a string as specified by the dimension style, then strcat the whole thing together and use something similar to this to returm the bounding box.
Fatty
« Reply #2 on: November 18, 2006, 04:48:17 AM »
Use GetSubentity method and you'll have a luck :)
~'J'~
