Author Topic: extract length of solid  (Read 2035 times)
David Hall
  • Automatic Duh Generator
« on: November 16, 2006, 05:13:32 PM »
I have a "sweep" that is a circle extruded along a path.  What I would like to do is extract the length out of the solid.  I used getentity to see that it was a sweep, but couldn't find any property that matched the known length for that solid.
Ideas???
Bryco
Re: extract length of solid
« Reply #1 on: November 16, 2006, 05:28:29 PM »
Not available in vb.
Fatty
« Reply #2 on: November 16, 2006, 05:46:16 PM »
Ideas???
Just an idea:
Volume/Circle area
~'J'~
It's Alive!
  • Retired
  • AKA Daniel
« Reply #3 on: November 16, 2006, 05:52:59 PM »
Maybe you can try measuring the path before you extrude or getboundingbox? Once it’s a solid there is not much data you can pull from it
Dan
