Author Topic: A linear equation set solver, thank to Evgeniy's help.  (Read 7626 times)
qjchen
  • Best wishes to all
« on: November 11, 2006, 07:15:14 AM »
My original meaning is to test a matrix inverse function.
After Evgeniy's convert function, now it can solve some linear equation set:)
Sorry for the tedious code :)
;;; some the following code are writen by   QJCHEN     ;
;;; Purpose: A equation solver function                ;
;;; Great thanks to ElpanovEvgeniy at theswamp,        ;
;;;        his function to seperate the variable and   ;
;;;        the number give me great help               ;
;;; Usage: select some texts like 1x+2y+3z+0a-5b+6d=5  ;
;;;        Then if the equation set has solution,      ;
;;;        it will give out                            ;
;;;        else, it will get error                     ;
;;; Note:  This code is just to test my matrix inverse ;
;;;        function, I find it is not so convenient to ;
;;;        do matrix operation in Lisp                 ;
;;; 2006.11.11                                         ;
(defun c:test (/ pub rlst lalllst c h)
  (setq pub (gettext))
  (getlst pub)
  (result)
;;; Function to get text and convert it to new lst    ;
(defun gettext (/ sstext n i obj ent text res lstall lsttext)
  (setq sstext (ssget))
  (if sstext
      (setq n (sslength sstext)
            i 0
      (repeat n
        (setq obj (ssname sstext i))
        (setq ent (entget obj))
        (setq text (cdr (assoc 1 ent))
              h    (cdr (assoc 40 ent))
        (setq lsttext (formula->list_01 (list text)))
        (setq lstall (append
                       lstall
                       (list lsttext)
        (setq res lstall)
        (setq i (1+ i))
  res
;;; Function to deal with the new lst and get the     ;
;;;          left and right matrix                    ;
(defun getlst (pub / x y llst)
  (setq c nil)
  (foreach x pub
    (foreach y x
      (setq c (append
                c
                (list (car y))
  (setq c (STD-REMOVE-DUPLICATES c))
  (setq c (vl-sort c '<))
  (setq rlst nil
        lalllst nil
  (foreach y pub
    (setq llst nil)
    (foreach x c
      (if (= x "=")
          (setq rlst (append
                       rlst
                       (list (list (cdr (assoc x y))))
          (if (assoc x y)
              (setq llst (append
                           llst
            (setq llst (append
                         llst
                         (list 0.0000)
    (setq lalllst (append
                    lalllst
                    (list llst)
;;; Function to write down the result                 ;
(defun result (/ str tempstr i x str pp)
  (setq temp (matrix_inversion lalllst))
  (setq temp2 (matrix-mul temp rlst))
  (setq str "")
  (setq tempstr (mapcar
                  '(lambda (x)
                     (rtos (nth 0 x) 2 3)
                  temp2
  (setq i 1)
  (foreach x tempstr
    (setq str (strcat str (nth i c) "=" x " "))
    (setq i (1+ i))
  (setq pp (getpoint "select a point to place the result:\n"))
  (command "text" pp h 0 str)
;;; N*N matrix inverse function  ,by qjchen           ;
(defun matrix_inversion (a     /     nmax  ipiv  indxr indxc n
                         n     i     j     k     l     ll    a-temp
                         temp  big   irow  icol  pivinv
  (setq nmax 50)
  (setq ipiv (create nmax))
  (setq indxr (create nmax))
  (setq indxc (create nmax))
  (setq n (length a))
  (setq i 1)
  (repeat n
    (setq big 0)
    (setq j 1)
    (repeat n
      (if (/= ([n] ipiv j) 1)
          (setq k 1)
          (repeat n
            (if (= ([n] ipiv k) 0)
                (if (>= (abs ([n,m] a j k)) big)
                    (setq big ([n,m] a j k))
                    (setq irow j)
                    (setq icol k)
                    (if (> ([n] ipiv k) 1)
                      (princ "singular matrix")
            (setq k (1+ k))
      (setq j (1+ j))
    (setq temp (1+ ([n] ipiv icol)))
    (setq ipiv (std-setnth temp (1- icol) ipiv))
    (if (/= irow icol)
        (setq l 1)
        (repeat n
          (setq dum ([n,m] a irow l))
          (setq a-temp ([n,m] a icol l))
          (setq a (qj-setnmth a-temp (1- irow) (1- l) a))
          (setq a (qj-setnmth dum (1- icol) (1- l) a))
          (setq l (1+ l))
    (setq indxr (std-setnth irow (1- i) indxr))
    (setq indxc (std-setnth icol (1- i) indxc))
    (if (= ([n,m] a icol icol) 0)
      (princ "singular matrix, the equations have no solve")
    (setq pivinv (/ 1.0 ([n,m] a icol icol)))
    (setq a (qj-setnmth 1 (1- icol) (1- icol) a))
    (setq l 1)
    (repeat n
      (setq a-temp (* ([n,m] a icol l) pivinv))
      (setq a (qj-setnmth a-temp (1- icol) (1- l) a))
      (setq l (1+ l))
    (setq ll 1)
    (repeat n
      (if (/= ll icol)
          (setq dum ([n,m] a ll icol))
          (setq a (qj-setnmth 0.0 (1- ll) (1- icol) a))
          (setq l 1)
          (repeat n
            (setq a-temp (- ([n,m] a ll l) (* dum ([n,m] a icol l))))
            (setq a (qj-setnmth a-temp (1- ll) (1- l) a))
            (setq l (1+ l))
      (setq ll (1+ ll))
    (setq i (1+ i))
  (setq l n)
  (repeat n
    (if (/= ([n] indxr l) ([n] indxc l))
        (setq k 1)
        (repeat n
          (setq dum ([n,m] a k ([n] indxr l)))
          (setq a-temp ([n,m] a k ([n] indxc l)))
          (setq a (qj-setnmth a-temp (1- k) (1- ([n] indxr l)) a))
          (setq a (qj-setnmth dum (1- k) (1- ([n] indxc l)) a))
          (setq k (1+ k))
    (setq l (1- l))
  a
;;; create a list with m 0.0 element ,by qjchen       ;
(defun create (m / lista)
  (setq lista nil)
  (repeat m
    (setq lista (append
                  lista
                  (list 0.0)
  lista
;;; create a list with m*m  0.0 element ,by qjchen    ;
(defun createm (m / lista listb)
  (setq m 5)
  (setq lista nil)
  (repeat m
    (setq listb nil)
    (repeat m
      (setq listb (append
                    listb
                    (list 0.0)
    (setq lista (append
                  lista
                  (list listb)
  lista
;;; a function that Evgeniy write for me :)           ;
(defun formula->list_01 (lst)
  ;; Version 2
  ;; not use VLA- function...
  ;; Argument - (list "formula string")
  ;; By ElpanovEvgeniy
  ;; For qjchen
  ;; when I have a string of  "3x+5y+7z+5a+7b-9c=0"
  ;; how could I write a function to seperate them to (x . 3) (y . 5)
  ;; that a dot pair, so the string sequence of the equation solver be
  ;; more
  ;; flexible
  ;; but when I try to use (assoc "X" lst) or (assoc X lst)
  ;; it return nil. maybe I get wrong use of assoc?
  ;; what method will be better to get the "X" 's value-- 3.1
  ;;test:
  ;;(formula->list_01 '("3.1xxa+8xxb+7xxc+5abcd+7ef-9c=0"))
  ;; '(("xxa" . 3.1) ("xxb" . 8.0) ("xxc" . 7.0) ("abcd" . 5.0) ("ef" .
  ;; 7.0) ("c" . -9.0) ("="
  ;; 0.0))
    ((= (cadr lst) "") nil)
    ((not (cdr lst))
     (formula->list_01
       (list
         (list (substr (car lst) 1 1))
         (substr (car lst) 2)
       ) ;_  list
     ) ;_  formula->list_01
    ((and
       (not (cadar lst))
       (WCMATCH (substr (cadr lst) 1 1) "#,.,+,-,")
     ) ;_  and
     (formula->list_01
       (list
         (list (strcat (caar lst) (substr (cadr lst) 1 1)))
         (substr (cadr lst) 2)
       ) ;_  setq
    ((= (substr (cadr lst) 1 1) "=")
     (list
       (cons
         (cadar lst)
         (atof (caar lst))
       ) ;_  cons
       (cons "=" (atof (substr (cadr lst) 2)))
     ) ;_  list
    ((WCMATCH (substr (cadr lst) 1 1) "[a-z],[A-Z]")
     (formula->list_01
       (list
         (list
           (caar lst)
           (strcat (if (cadar lst)
                     (cadar lst)
                   ) ;_  if
           ) ;_  strcat
         ) ;_  list
       ) ;_  list
    (t
     (cons
       (cons
         (cadar lst)
         (atof (caar lst))
       ) ;_  cons
       (formula->list_01
         (cdr lst)
     ) ;_  cons
    ) ;_  t
  ) ;_  cond
;;; STDLIB func: substitute the nth element of a list ;
(defun std-%setnth (new i lst / fst len)
    ((minusp i)
     lst
    ((> i (setq len (length lst)))
     lst
    ((> i (/ len 2))
     (reverse (std-%setnth new (1- (- len i)) (reverse lst)))
    (t
     (append
         (setq fst nil)                 ; ; possible vl lsa compiler
                                        ; bug
         (repeat (rem i 4)
           (setq fst (cons (car lst) fst)
                 lst (cdr lst)
         (repeat (/ i 4)
           (setq fst (cons (cadddr lst)
                           (cons (caddr lst)
                                 (cons
                                   (cadr lst)
                                   (cons
                                     (car lst)
                                     fst
                 lst (cddddr lst)
         (reverse fst)
       (if (listp new)
         new
         (list new)
       (cdr lst)
(defun std-setnth (new i lst)
  (std-%setnth (list new) i lst)
;;; STDLIB func:remove duplicate element of a list    ;
;;; by Serge Pashkov The below mentioned lsa          ;
;;;        compiler bug couldn't be isolated yet.     ;
(defun STD-REMOVE-DUPLICATES (lst / ele new)
  (setq new nil)                        ; possible VL lsa compiler bug
  (foreach ele lst
    (if (not (member ele new))
      (setq new (cons ele new))
  (reverse new)
;;; func:substitute the i row j column element        ;
;;;          of a list                            ;
(defun qj-setnmth (new i j lst / listb lista)
  (setq listb lst)
  (setq lista (nth i lst))
  (setq lista (std-setnth new j lista))
  (setq listb (std-setnth lista i listb))
  listb
;;; func:get the value of the n row m column element  ;
;;;      of a 2 dimension list                        ;
(defun [n,m] (a n m / i)
  (setq i (nth (1- m) (nth (1- n) a)))
  i
;;; func:get the value of the n-th element of a       ;
;;;           1 dimension list                        ;
(defun [n] (a n / i)
  (setq i (nth (1- n) a))
  i
;;; func:A function of multiply of two matrix         ;
(defun matrix-mul (m1 m2 / m3 m4 m33 x y)
  (setq m3  nil
        m33 nil
  (setq m4 (mtr m2))
  (foreach x m1
    (setq m33 nil)
    (foreach y m4
      (setq m (apply
                (mapcar
                  x
                  y
      (setq m33 (append
                  m33
                  (list m)
    (setq m3 (append
               m3
               (list m33)
  m3
(defun mtr (x)
  (apply
    'mapcar
    (cons 'list x)
(princ "\n type TEST to run the equation solver, by qjchen\n")
« Last Edit: June 10, 2022, 05:31:54 AM by qjchen »
http://qjchen.mjtd.com
Re: A linear equation set solver, thank to Evgeniy's help.
« Reply #1 on: November 11, 2006, 08:21:36 AM »
That's cool stuff Chen! Thanks for sharing. :-)
SomeCallMeDave
« Reply #2 on: November 11, 2006, 08:25:40 PM »
Great work!!    I can't wait to dig into it deeper.  Thanks for this and all your great posts..
CADaver
« Reply #3 on: November 13, 2006, 01:54:43 PM »
Now that's sweet, Thanks.
qjchen
« Reply #4 on: November 13, 2006, 07:10:04 PM »
Thank you, Mark, Dave and Cadaver.
I learn a lot from here, and just share a little, I will try to write more, and need your help:)
I use a bad method to write the matrix inverse code, but Evgeniy was using mapcar to write it, I think it will be much beautiful code.
Keep one learing Lisp every day~~~
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #5 on: November 14, 2006, 10:15:48 AM »
(defun c:cce (/ LP LST)
  ;; by ElpanovEvgeniy
  ;; Calculation of the connected equations
  ;; 13.11.2006
  ;; (c:cce)
  (if (setq lst (text-equation-list))
      (setq
        lp  (append
              (ACAD_STRLSORT
                (rem-dupl
                  (vl-remove "=" (apply (function append) (mapcar (function car) lst)))
                ) ;_  rem-dupl
              ) ;_  ACAD_STRLSORT
            ) ;_  append
        lst (vl-remove-if
              (function (lambda (x) (vl-every (function zerop) x)))
              (gauss
                (mapcar
                  (function
                    (lambda (x)
                      (mapcar
                        (function
                          (lambda (a)
                            (if (assoc a (cadr x))
                              (cdr (assoc a (cadr x)))
                              0.
                            ) ;_  if
                          ) ;_  lambda
                        ) ;_  function
                        lp
                      ) ;_  list
                    ) ;_  lambda
                  ) ;_  function
                  lst
                ) ;_  mapcar
              ) ;_  gauss
            ) ;_  vl-remove-if
      ) ;_  setq
      (if (= (1- (length (car lst))) (length lst))
        (if (and (= (length (vl-remove-if (function zerop) (last lst))) 1)
                 (not (zerop (last (last lst))))
            ) ;_  and
          (entmakex
            (list
              '(0 . "MTEXT")
              '(100 . "AcDbEntity")
              '(100 . "AcDbMText")
              (cons 10 (getpoint "\nselect a point to place the result:"))
              '(1 . "This set of equations\n has no solutions!")
            ) ;_  list
          ) ;_  entmakex
          (entmakex
            (list
              '(0 . "MTEXT")
              (cons
                1
                (apply
                  (function strcat)
                  (mapcar
                    (function
                      (lambda (a b)
                        (strcat
                          a
                          (rtos (apply (function /) (reverse (vl-remove-if (function zerop) b)))
                                2
                                8
                          ) ;_  rtos
                          "\n"
                        ) ;_  strcat
                      ) ;_  lambda
                    ) ;_  function
                    lp
                    (mapcar
                      (function (lambda (x) (cdr (reverse (cons (last x) x)))))
                      (reverse
                        (gauss
                          (reverse
                            (mapcar (function (lambda (x) (cdr (reverse (cons (last x) x))))) lst)
                          ) ;_  reverse
                        ) ;_  gauss
                      ) ;_  reverse
                    ) ;_  reverse
                  ) ;_  mapcar
                ) ;_  apply
              ) ;_  cons
            ) ;_  list
          ) ;_  entmakex
        ) ;_  if
          (setq lst (reverse
                      (mapcar
                        (function
                          (lambda (x)
                            (vl-remove-if
                              (function (lambda (x1) (zerop (cdr x1))))
                              (mapcar (function cons) lp x)
                            ) ;_  vl-remove-if
                          ) ;_  lambda
                        ) ;_  function
                        (mapcar
                          (reverse
                            (gauss
                              (reverse
                                        lst
                                ) ;_  mapcar
                              ) ;_  reverse
                            ) ;_  gauss
                          ) ;_  reverse
                        ) ;_  mapcar
                      ) ;_  mapcar
                    ) ;_  reverse
          ) ;_  setq
          (if (= 1 (length (last lst)))
            (entmakex
              (list
                '(0 . "MTEXT")
              ) ;_  list
            ) ;_  entmakex
            (entmakex
              (list
                '(0 . "MTEXT")
                (cons
                  1
                  (apply
                    (function strcat)
                    (mapcar
                      (function
                        (lambda (x)
                          (apply
                            (function strcat)
                            (append
                              (mapcar
                                (function
                                  (lambda (a)
                                    (if (= (car a) "=")
                                      (strcat (car a) (rtos (cdr a) 2 8))
                                        ((equal (cdr a) 1. 1e-8) (car a))
                                        ((equal (cdr a) -1. 1e-8) (strcat "-" (car a)))
                                        ((minusp (cdr a)) (strcat (rtos (cdr a) 2 8) (car a)))
                                        (t (strcat "+" (rtos (cdr a) 2 8) (car a)))
                                      ) ;_  cond
                                    ) ;_  if
                                  ) ;_  lambda
                                ) ;_  function
                                x
                              ) ;_  mapcar
                              '("\n")
                            ) ;_  append
                          ) ;_  apply
                        ) ;_  lambda
                      ) ;_  function
                      (reverse
                        (Simplification-equations
                          (mapcar
                            (function
                              (lambda (x)
                                (append
                                  (list (car x) (last x))
                                  (mapcar
                                    (function (lambda (a) (cons (car a) (- (cdr a)))))
                                    (reverse (cdr (reverse (cdr x))))
                                  ) ;_  mapcar
                                ) ;_  append
                              ) ;_  lambda
                            ) ;_  function
                            lst
                          ) ;_  mapcar
                        ) ;_  Simplification-equations
                      ) ;_  reverse
                    ) ;_  mapcar
                  ) ;_  apply
                ) ;_  cons
              ) ;_  list
            ) ;_  entmakex
          ) ;_  if
        ) ;_  progn
      ) ;_  if
    ) ;_  progn
  ) ;_  if
) ;_  defun
(defun Simplification-equations (l)
  ;; Simplification of the connected equations
(Simplification-equations '((("C" . 1.0) ("=" . -3.0) ("D" . -1.0))
       (("B" . 1.0) ("=" . -3.0) ("C" . 2.0))
       (("A" .  1.0) ("=" . 4.0) ("B" .  2.0))
  (("B" . 1.0) ("=" . -9.0) ("D" . -2.0))
  (("A" . 1.0)  ("=" . -14.0) ("D" .  -4.0))
  (if (cdr l)
    (cons
      (cons (cons (caaar l) 1.)(mapcar(function(lambda(x)(cons (car x)(/ (cdr x)(cdaar l)))))(cdar l)))
        (cons
          (cons
            (cons (caaadr l) 1.)
            (cons
              (cons
                (+ (cdr (assoc "=" (cadr l)))
                   (* (/(cdr (assoc (caaar l) (cadr l)))(cdaar l)) (cdr (assoc "=" (car l))))
                ) ;_  +
              ) ;_  cons
              (mapcar
                (function (lambda (x) (cons (car x) (* (cdr x) (/(cdr (assoc (caaar l) (cadr l)))(cdaar l))))))
                (cddar l)
              ) ;_  mapcar
            ) ;_  cons
          ) ;_  cons
          (cddr l)
        ) ;_  cons
    ) ;_  cons
    (list (cons (cons (caaar l) 1.)(mapcar(function(lambda(x)(cons (car x)(/ (cdr x)(cdaar l)))))(cdar l))))
  ) ;_  if
) ;_  defun
(defun rem-dupl (lst)
  ;; Deleting of all identical objects
  ;; (rem-dupl '(1 2 3 2 1))=>(1 2 3)
  (if lst
    (cons (car lst) (rem-dupl (vl-remove (car lst) (cdr lst))))
  ) ;_  if
) ;_  defun
(defun gauss (lst)
  ;; Implementation Gaussian elimination
  ;; For text:
  ;  1x+2y+3z=2
  ;  10x+1y+8z=17
  ;  7z+2y=5
  ;; (gauss '((1.0 2.0 3.0 2.0) (10.0 1.0 8.0 17.0) (0.0 2.0 7.0 5.0)))
  ;; ((1.0 2.0 3.0 2.0) (0.0 -19.0 -22.0 -3.0) (0.0 0.0 4.68421 4.68421))
  ;;(gauss lst)
  (if (car lst)
    (if (zerop (caar lst))
      (if (vl-every (function zerop) (mapcar (function car) lst))
        (if (cdr lst)
          (cons
            (car lst)
            (mapcar
              (function (lambda (x) (cons 0. x)))
              (gauss (mapcar (function cdr) (cdr lst)))
            ) ;_  mapcar
          ) ;_  cons
          lst
        ) ;_  if
        (gauss
          (cons
            (mapcar
              (function +)
              (car lst)
              (car (vl-remove-if (function (lambda (x) (zerop (car x)))) (cdr lst)))
            ) ;_  mapcar
            (cdr lst)
          ) ;_  cons
        ) ;_  gauss
      ) ;_  if
      (cons
        (car lst)
        (mapcar
          (gauss
            (mapcar
              (function
                (lambda (x / i)
                  (setq i (/ (car x) (caar lst)))
                  (mapcar
                    (function -)
                    (cdr x)
                    (mapcar (function (lambda (x1) (* x1 i))) (cdar lst))
                  ) ;_  mapcar
                ) ;_  lambda
              ) ;_  function
              (cdr lst)
            ) ;_  mapcar
          ) ;_  test
        ) ;_  mapcar
      ) ;_  cons
    ) ;_  if
  ) ;_  if
) ;_  defun
(defun text-equation-list (/ s)
  ;; select text equation and create list
  ;; For text:
  ;  1x+2y+3z=2
  ;  10x+1y+8z=17
  ;  7z+2y=5
  ;; (text-equation-list)
  ;|'((("X" "Y" "Z" "=") (("X" . 1.0) ("Y" . 2.0) ("Z" . 3.0) ("=" . 2.0)))
       (("X" "Y" "Z" "=") (("X" . 10.0) ("Y" . 1.0) ("Z" . 8.0) ("=" . 17.0)))
       (("Z" "Y" "=") (("Z" . 7.0) ("Y" . 2.0) ("=" . 5.0)))
  (if (setq s (ssget '((0 . "TEXT"))))
    (mapcar
      (function
        (lambda (str)
          (setq
            str (mapcar
                  (function cons)
                  (mapcar
                    (function VL-PRINC-TO-STRING)
                    (read
                      (strcat
                        (VL-STRING-TRANSLATE
                          "0123456789.=+-"
                          str
                        ) ;_  VL-STRING-TRANSLATE
                      ) ;_  strcat
                    ) ;_  read
                  ) ;_  mapcar
                  (mapcar
                    (function FLOAT)
                    (subst
                      -1
                      (subst
                        1
                        (read
                          (strcat
                              "abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ="
                                ((WCMATCH (substr str 1 1) "[a-z],[A-Z]") (strcat "1" str))
                                ((WCMATCH (substr str 1 2) "-[a-z],-[A-Z]")
                                 (strcat "-1" (substr str 2))
                                (t str)
                              ) ;_  cond
                          ) ;_  strcat
                        ) ;_  read
                      ) ;_  subst
                    ) ;_  subst
                  ) ;_  mapcar
                ) ;_  mapcar
          ) ;_  setq
          (list (mapcar (function car) str) str)
        ) ;_  lambda
      ) ;_  function
      (mapcar
        (function (lambda (x) (cdr (assoc 1 (entget x)))))
        (vl-sort
          (vl-remove-if (function listp) (mapcar (function cadr) (ssnamex s)))
          (function
            (lambda (a b)
              (> (caddr (assoc 10 (entget a))) (caddr (assoc 10 (entget b))))
            ) ;_  lambda
          ) ;_  function
        ) ;_  vl-sort
      ) ;_  mapcar
    ) ;_  mapcar
  ) ;_  if
) ;_  defun
The magenta text - outcome of operation of the program...
« Last Edit: November 14, 2006, 10:43:22 AM by ElpanovEvgeniy »
qjchen
« Reply #6 on: November 14, 2006, 07:19:38 PM »
Thank you, Evgeniy.
a beautiful code, let me study hard for it.:)
« Reply #7 on: November 14, 2006, 07:27:29 PM »
Evgeniy, that code is a thing of beauty !!
