Author Topic: Evaluate a list and return the nil  (Read 14807 times)
« Reply #15 on: October 23, 2003, 12:53:18 PM »
looks correct to me, but se7en while have to make the final say-so since he started this mess........:D
« Reply #16 on: October 23, 2003, 12:54:34 PM »
if you are after the index, this may suit :
(defun test (theList / tmp)
  (if (setq tmp (member nil theList))
    (1+ (- (length theList) (length tmp)))
    nil
« Reply #17 on: October 23, 2003, 01:03:01 PM »
Oh i dont care. I was origionaly looking for the opposite of "cond" like it was the fountian of youth or something but anyof those will do.  Thanx alot guys.
« Reply #18 on: October 23, 2003, 01:07:11 PM »
If i had to pick one i would have to say marks because its cleaner.  But their all cool.
« Reply #19 on: October 23, 2003, 01:15:16 PM »
< snip > and I want to run thru the list to see what member dose not have a value.
I can use a "(mapcar 'cond "mylist")" to evaluate each member of my list but that dosent tell me which one in the list is nil.
ahh ok ..
