Author Topic: Evaluate a list and return the nil  (Read 14806 times)
« on: October 22, 2003, 09:54:35 AM »
I was thinking this morning and i have been trying to come up with a slick way to test a list and return the nil member of a list. I cant think of anything. (Am i missing anything?) What is the opposite of "cond"? Is there one?
The only thing i could come up with is: "(mapcar 'cond '(a b c d))" to evaluate each member of the list but all i get is something like "(T T T nil)" as a return. I was wondering if anyone knew of a way to return the item that is nil in a list?
Am i nuts?! ...I must be nuts.
« Reply #1 on: October 22, 2003, 10:33:29 AM »
do what..............
I think you've been taking to much cold medicine. :D
hendie
« Reply #2 on: October 22, 2003, 10:53:10 AM »
funnily enough I was trying to do exactly the same thing two days ago.
I gave up    :roll:
« Reply #3 on: October 22, 2003, 10:56:14 AM »
:? Smartass! Funny, cause I need to go get more. (I'm out)
Ok, lets say I have a list of stuff.
(setq a 1 b 2 c 3 d nil)
and I want to run thru the list to see what member dose not have a value.
I can use a "(mapcar 'cond "mylist")" to evaluate each member of my list but that dosent tell me which one in the list is nil.
« Reply #4 on: October 22, 2003, 11:09:07 AM »
Well it can be done. Here is "a way" but it aint smoooth (like me)
Run each of these lines in your vlide and watch the return values.
  (setq x (list a b c d))
  (setq y '(a b c d))
  (setq n (- (length x) 1))
  (setq nu
        (1+ (while
              ;; test each
              (equal (nth n x) nil)
              ;; drop the n variable down one increment
              (setq n (1- n))
 ;; return the nil variable.
  (nth nu y)
SomeCallMeDave
« Reply #5 on: October 22, 2003, 11:10:03 AM »
If you are sure that you only will have one nil, you could use vl-position
Command: (setq aa (list "A" "b" nil "c"))
("A" "b" nil "c")
Command: (vl-position nil aa)
2
« Reply #6 on: October 22, 2003, 11:11:38 AM »
Quote from: SomeCallMeDave
("A" "b" nil "c")
2
Oh crap! im sorry, i forgot to mention that i wanted a way without VL. But nice.
Edit: Im actualy just playing around with the lisp language; looking for cool stuff that i overlooked.  Sorry, i prolly should have mentioned that huh?!
« Reply #7 on: October 22, 2003, 11:25:48 AM »
OK..........now you're startin to make sense. :D
Check out he eval function.
(if (not (eval x))(prompt "is nil.."))
« Reply #8 on: October 23, 2003, 07:32:37 AM »
Se7en,
Putting the nil in the middle of the list resulted in error.
I had to move the 1+ for the index var and don't see why eval is needed.
Still just a variation on your routine..
 (setq a 1 b 2 c nil d 3)
  (setq y '(a b c d))
  (setq nu (while
    (nth n x)
    (setq n (1- n))
  (nth (1+ nu) y)
« Reply #9 on: October 23, 2003, 07:49:35 AM »
This appears to work as well.
 (setq a 1 b nil c 3 d 4)
  (setq y '(a b c d))
  (setq nu (-(length x)(length (member nil x))))
  (nth nu y);; return the nil variable. If no nil returns nil
« Reply #10 on: October 23, 2003, 08:07:32 AM »
 (setq syms '(a b c d))
  (foreach item syms
    (if (not (eval item))
      (princ item)
« Reply #11 on: October 23, 2003, 12:34:17 PM »
am I missing something ??
 (setq xxxx (list 1 2 3 nil 5 6))
==>> (1 2 3 nil 5 6)
(member nil xxxx)
==>> (nil 5 6)
(length xxxx) ==>> 6
(length nil) ==>> 0
(length (member nil xxxx)) ==>> 3
« Reply #12 on: October 23, 2003, 12:39:13 PM »
Quote from: Kerry B
(member nil xxxx)
==>> (nil 5 6)
member function
Searches a list for an occurrence of an expression and returns the remainder of the list, starting with the first occurrence of the expression
« Reply #13 on: October 23, 2003, 12:42:23 PM »
yep
.. if the return from (member nil xxxx) is not nil
(- (length xxxx) (length (member nil xxxx))) will be the position of the nil.
it's early here, so I may be incorrect :) need coffee
« Reply #14 on: October 23, 2003, 12:52:54 PM »
Mark, That is what i was attmepting to do. Damn! I cant find my "foreach" test. (I must have destroyed it.) But it was craaaazy.
Look at this one:
"(mapcar 'if (not (cond (eval x))) (setq x (princ "this one")) '(a b c d))"
Dahell is that?!!!
Kids, do you see what cold med's do to your mind. They make you go nuts!
