Author Topic: XSTEEL (Tekla structurtes) and Autocad  (Read 4890 times)
Amsterdammed
« on: November 09, 2006, 05:07:48 AM »
Hello there,
in our current project we have to design the mechanical installations in a complex building. The building is made from steel and designed in XSTEEl.
Is there any possibility to export the xsteel drawing with all the 3d functionality to acad2006 so that i can use it as 3d xref?
Thanks in advance
Bernd
Re: XSTEEL (Tekla structurtes) and Autocad
« Reply #1 on: November 09, 2006, 05:19:43 AM »
What do you mean by this ? exactly.
« Reply #2 on: November 09, 2006, 05:22:37 AM »
My memory of XSteel is quite old ... you may be better served asking on their forum .. I don't recall any mention of XSteel here previously
Amsterdammed
« Reply #3 on: November 09, 2006, 05:29:25 AM »
I meant if they can export to Acad in, let's say solids of surfaces, something you can work further in Acad
Bernd
