Author Topic: Blocks on wrong layers  (Read 2841 times)
Matersammichman
« on: November 01, 2006, 05:57:19 PM »
VBA-
Okay, I am ***** by blocks and xrefs that do not reside on layer zero.
How do I collect the Blocks collection, then place all of the blocks and xrefs on layer 0?
mohnston
  • CAD Programmer
Re: Blocks on wrong layers
« Reply #1 on: November 01, 2006, 07:38:15 PM »
VBA-
1. Get a selection set of all acadblockreference and acadexternalreference objects.
2. Iterate through each item in the selection set setting its layer to "0".
Public Sub BlocksAndXrefsToZeroLayer()
    Dim oEnt As AcadEntity
    Dim I As Integer
    Dim oSS As AcadSelectionSet
    Dim iType(3) As Integer
    Dim vData(3) As Variant
    Dim P1(2) As Double
    Dim P2(2) As Double
    Set oSS = getSS("zlayer")
    iType(0) = -4: vData(0) = "<OR"
    iType(1) = 0: vData(1) = "INSERT"
    iType(2) = 0: vData(2) = "XREF"
    iType(3) = -4: vData(3) = "OR>"
    oSS.Select acSelectionSetAll, P1, P2, iType, vData
    If oSS.Count < 1 Then Exit Sub
    For I = 0 To oSS.Count - 1
        Set oEnt = oSS(I)
        If ThisDrawing.Layers(oEnt.Layer).Lock Then
            ' entity is on a locked layer - can't change it
        Else
            oEnt.Layer = "0"
            oEnt.Update
        End If
    Next
End Sub
Public Function getSS(strName As String) As AcadSelectionSet
    Dim SS As AcadSelectionSet
    On Error Resume Next
    ThisDrawing.SelectionSets(strName).Delete
    Set SS = ThisDrawing.SelectionSets.Add(strName)
    Set getSS = SS
End Function
CAD Programming Solutions
Matersammichman
« Reply #2 on: November 02, 2006, 06:06:48 AM »
Thanks Mark, I'll give it a shot.
Matersammichman
« Reply #3 on: November 02, 2006, 12:47:35 PM »
Mark,
Fantastic code!
Thanks!
