Author Topic: Clipboard.arx by Luis E  (Read 6525 times)
mhakim
« on: October 31, 2006, 07:52:49 PM »
Not too sure where to post this request.
I'm in need of "clipboard.arx" by Luis E.
His website : http://www.geometricad.com/ is no longer downloadable.
I have the "doslib" which has the "clipoard" function but am reluctant to autoload it since I'm only interested in using the "clipboard" function.
Thank you in advance.
« Last Edit: November 01, 2006, 09:53:02 AM by mhakim »
Re: Clipboard.arx by Luis E
« Reply #1 on: October 31, 2006, 08:51:06 PM »
[Personal opinion]
Use the Doslib ARX. It is available for all builds of ACAD ... it's a professional package and has an abundance of functionality that you will find usefull.
LE
« Reply #2 on: October 31, 2006, 09:57:11 PM »
« Reply #3 on: October 31, 2006, 10:10:23 PM »
I thought you wanted out of the software industry Luis ... are you prepared to support it and rebuild it for each new AutoCAD build ?
LE
« Reply #4 on: October 31, 2006, 10:19:01 PM »
Hi Kerry;
I was joking my friend  :-).... please ignore the previous emoticon....  :evil:
Now, going back to OP request, I will post the ARX file here [in case became useful]
For AutoCAD 2004, 2005, 2006
ClipBoard Functions:
Usage: (SetClipboardText <String>)
Usage: (GetClipboardText)
Usage: (EmptyClipboard)
« Last Edit: November 01, 2006, 07:36:17 PM by LE »
mhakim
« Reply #5 on: October 31, 2006, 10:24:50 PM »
Thanx a zillion Luis.
LE
« Reply #6 on: October 31, 2006, 10:53:14 PM »
I just updated the project for AutoCAD 2007.
Here is:
Correction: I uploaded previously the DEBUG version, here is the RELEASE one - sorry.
« Last Edit: October 31, 2006, 11:28:04 PM by LE »
LE
« Reply #7 on: October 31, 2006, 11:10:55 PM »
Yes. - at least by myself.
Coding still it is my first hobby - janitorial services my second - and lately preparing hamburgers will be my third one....  :kewl:
No. - the project is abandoned - what I posted here is provided AS-IS
LE
« Reply #8 on: October 31, 2006, 11:14:34 PM »
Good.
If it works, I did it... if not, someone else wrote it...
