Author Topic: running vlx thru lisp  (Read 1998 times)
viva
« on: October 31, 2006, 12:30:26 AM »
hi
     i want 2 run .vlx file through lisp. that means first one process wants 2 execute then vlx wants 2 execute. can anyone give me idea
regards
viva
Re: running vlx thru lisp
« Reply #1 on: October 31, 2006, 01:30:02 AM »
If the code in the VLX is functions just treat them like normal lisp routines. < just make sure the VLX is loaded beforehand >
Is the VLX compiled into a seperate namespace ??? if so, you will have to export the function names into the current document namespace ...
