This is a work around. You get a string of names from a function then use that for your filter.
Function SelectDynamicByName(sName As String) As String
Dim sArray As String
Dim oBref As AcadBlockReference
Dim SS As AcadSelectionSet
sArray = sName
Set SS = sset(2, "`*U*") 'Use a selectionset function
For Each oBref In SS
If oBref.IsDynamicBlock Then
If oBref.EffectiveName = sName Then
sArray = sArray & ",`" & oBref.Name
End If
End If
Next
SelectDynamicByName = sArray
End Function
Sub Test()
Set SS = sset(2, SelectDynamicByName("Door - Imperial"))
Debug.Print SS.count
Public Function sset(FilterType, FilterData As Variant, Optional ssName As String = "SS") As AcadSelectionSet
Dim oSSets As AcadSelectionSets
Set oSSets = ThisDrawing.SelectionSets
For Each sset In oSSets
If sset.Name = ssName Then
sset.Delete
Exit For
End If
Next
Dim FType() As Integer
Dim FData() As Variant
Dim i As Integer
If IsArray(FilterType) = False Then
If IsArray(FilterData) = False Then
ReDim FType(0)
ReDim FData(0)
FType(0) = FilterType
FData(0) = FilterData
Else
Exit Function
End If
Else
If UBound(FilterType) <> UBound(FilterData) Then
Exit Function 'They must be pairs
End If
ReDim FType(UBound(FilterType))
ReDim FData(UBound(FilterType))
For i = 0 To UBound(FilterType)
FType(i) = FilterType(i)
FData(i) = FilterData(i)
Next
End If
Set sset = ThisDrawing.SelectionSets.Add(ssName)
sset.Select 5, FilterType:=FType, FilterData:=FData
'To use this function for single filter
'Set SS = SSet(0, "insert")
'For multiple filter
'Set SS = SSet(array(0,2),array("insert",oBlock.name)) 'must be pairs
End Function
