Author Topic: Selectionset filter for dynamic blocks by name  (Read 3706 times)
mohnston
  • CAD Programmer
« on: October 30, 2006, 06:51:02 PM »
This is an AutoCAD 2007 issue.
I have upgraded (?) some blocks from standard blocks to dynamic blocks and now I find that some of my code will not find the blocks by name because dynamic blocks are assigned anonymous names. (*U???)
There is a new blockreference property, .EffectiveName, that I can use to build a selection set but I would prefer for users to see selections filtered during the selection and not after. Besides, I have other functions that rely on filtering on block name and I don't want to re-write them.
Is there a way to build a selection set filter that will look for DXF subclass markers?
For example:
0 = "INSERT"
2 = "s_elev*"
1001 = "AcDbDynamicBlockTrueName"
1000 = "s_elev*"
Or is there another way?
CAD Programming Solutions
Bryco
Re: Selectionset filter for dynamic blocks by name
« Reply #1 on: October 31, 2006, 07:34:16 AM »
This is a work around. You get a string of names from a function then use that for your filter.
Function SelectDynamicByName(sName As String) As String
    Dim sArray As String
    Dim oBref As AcadBlockReference
    Dim SS As AcadSelectionSet
    sArray = sName
    Set SS = sset(2, "`*U*") 'Use a selectionset function
    For Each oBref In SS
        If oBref.IsDynamicBlock Then
            If oBref.EffectiveName = sName Then
                sArray = sArray & ",`" & oBref.Name
            End If
        End If
    Next
    SelectDynamicByName = sArray
End Function
Sub Test()
    Set SS = sset(2, SelectDynamicByName("Door - Imperial"))
    Debug.Print SS.count
End Sub
Public Function sset(FilterType, FilterData As Variant, Optional ssName As String = "SS") As AcadSelectionSet
    Dim oSSets As AcadSelectionSets
    Set oSSets = ThisDrawing.SelectionSets
    For Each sset In oSSets
        If sset.Name = ssName Then
            sset.Delete
            Exit For
        End If
    Next
    Dim FType() As Integer
    Dim FData() As Variant
    Dim i As Integer
    If IsArray(FilterType) = False Then
        If IsArray(FilterData) = False Then
            ReDim FType(0)
            ReDim FData(0)
            FType(0) = FilterType
            FData(0) = FilterData
        Else
            Exit Function
        End If
    Else
        If UBound(FilterType) <> UBound(FilterData) Then
            Exit Function 'They must be pairs
        End If
        ReDim FType(UBound(FilterType))
        ReDim FData(UBound(FilterType))
        For i = 0 To UBound(FilterType)
            FType(i) = FilterType(i)
            FData(i) = FilterData(i)
        Next
    End If
    Set sset = ThisDrawing.SelectionSets.Add(ssName)
    sset.Select 5, FilterType:=FType, FilterData:=FData
    'To use this function for single filter
    'Set SS = SSet(0, "insert")
    'For multiple filter
    'Set SS = SSet(array(0,2),array("insert",oBlock.name)) 'must be pairs
End Function
End Sub
mohnston
  • CAD Programmer
« Reply #2 on: October 31, 2006, 12:43:03 PM »
Bryco,
Thank you very much for the excellent work-around.
It does what I want.
I had tried something like that but didn't know about the ` character.
Bryco
« Reply #3 on: October 31, 2006, 05:18:39 PM »
Glad it worked, I had to ask about that character as well, it's handy for a purge sub as dimension blocks need it too.
