Author Topic: Editing Attributes in a Block  (Read 2018 times)
Kheilmann
« on: October 30, 2006, 04:26:35 PM »
After inserting a block I need to rotate the attribute and change the alignment property
When Rotation Angle = 0 ' Nothing, the block is already setup this way
= 90 ' I need to rotate attr. 270 and change alignment to bottomCenter
=180 ' I need to rotate attr. 180 and change alignment to middleright
= 270 ' I need to roatate attr. 90 and change alignment to TopCenter
I'm just gettign weird resuts..Any help would be appreciated...
Guest
Re: Editing Attributes in a Block
« Reply #1 on: October 30, 2006, 04:39:51 PM »
What's your code look like?
Chuck Gabriel
« Reply #2 on: October 30, 2006, 07:47:56 PM »
Are you expressing your angles in degrees or radians?
Kheilmann
« Reply #3 on: October 30, 2006, 10:11:10 PM »
Sorry Guys, it was hard for me to explain what was going on exactly.  Basically, my problem was that I was rotating an Attribute in a Block from the Attributes INsertion Point, and the point I thought was the Attribute Insertion point was NOT, and so when I rotated, my text "moved" to different spots when I rotated at different angles.
Once I figured out how to set my TextIns point to the correct coordinates, everything worked great.
Sorry for any inconvenience....
Chuck Gabriel
« Reply #4 on: October 31, 2006, 08:04:35 AM »
Glad you figured it out.  Sounds like I was barking up the wrong tree anyway.
