Author Topic: importing maps through lisp  (Read 4441 times)
viva
« on: October 30, 2006, 05:06:26 AM »
hi everybody,
            hi everybody,
iam working in Autodesk map. i had tried to import the shape files into autodesk map through lisp. but i cant . can anyone help me regarding this issue
i had used
(command "mapimport" "d:\line.shp") ----- its helpless
regards
vivek
Re: importing maps through lisp
« Reply #1 on: October 30, 2006, 05:30:47 AM »
How about ;
(command "mapimport" "d:\\line.shp")
or
(command "mapimport" "d:/line.shp")
viva
« Reply #2 on: October 30, 2006, 05:35:34 AM »
hi kerry,
           thanks for ur immediate reply. that command is not working
regards
viva
« Reply #3 on: October 30, 2006, 06:29:35 AM »
don't have map, so was just a guess ...
be patient, someone will come along ..
Dinosaur
« Reply #4 on: October 30, 2006, 07:33:39 AM »
The mapimport command always comes up with a dialog to specify both the file name AND the file type (approx. 10 choices).  Same results when command is preceded with a "-" or a ".".  I don't know if there is a way around this or not with lisp or vba.
« Reply #5 on: October 30, 2006, 07:47:10 AM »
How about playing with the CMDDIA settings .. what happens if CMDDIA is 0 ??
Dinosaur
« Reply #6 on: October 30, 2006, 07:49:31 AM »
cmddia and filedia settings set at "0" still yield the dialog box
At least using ivil 3D 2007 . . . I can check 2005 in a minute.
« Last Edit: October 30, 2006, 07:51:02 AM by DinØsaur »
Dinosaur
« Reply #7 on: October 30, 2006, 07:59:36 AM »
Setting filedia to "0" will call for the command line input.  The first request is for the file type.  The response for his requested file is SHAPE.  then it requests a file path and name.
This is true for 2007 as well.
Guest
« Reply #8 on: October 30, 2006, 10:10:48 AM »
You need to specify the file type; in this case, SHAPE.
Give this a shot.  I don't have a SHP file to test so I don't know if there are any other prompts after the file name.
(setvar "filedia" 0)
(command "-mapimport" "shape" "d:/line.shp")
(setvar "filedia" 1)
mohobrien
« Reply #9 on: October 30, 2006, 07:20:50 PM »
This is a routine I used to import a whole series of shape files into 2000i
Most of the routine is garbage for you but the section that does the import works. Same ideas as everyone else has given.
(defun c:runimp (/ n ntsnum ntsnumlist source_folder nts_sheet dwgid)
  (setvar "cmddia" 0)
  (command "ucsicon" "OFF" "")
  (setq ntsnumlist
(list "01"   "02"   "03"   "04"   "05"   "06" "07" "08"
       "09"   "10"   "11"   "12"   "13"   "14" "15" "16"
  (setq nts_sheet "64L")
  (setq n 0)
  (while (< n 16)
    (setq ntsnum (nth n ntsnumlist))
    (setq source_folder
   (strcat "C:\\Drawings\\Topo83\\"
   nts_sheet
   ntsnum
    (command "MAPIMPORT" "SHAPE" source_folder "N" "P")
    (setq n (1+ n))
    (ade_projsetwscode "UTM83-13")
    (ade_dsattach
      (strcat "C:\\Drawings\\Topo\\"   nts_sheet
      "\\new_" nts_sheet   ntsnum
      ".dwg"
    (setq dwgid (ade_dwggetid
  nts_sheet     "\\new_"
  nts_sheet     ntsnum
  ".dwg"
    (ade_dwgactivate dwgid)
    (ade_qryclear)
    (ade_qrysettype "draw")
    (ade_qrydefine '("" "" "" "Location" ("all") ""))
    (ade_qrydefine
      '("AND"
"Property"
("layer" "=" "CORNER_COORD_TEXT,TopoText")
    (ade_qrysetaltprop nil)
    (ade_qryexecute)
    (ade_qryclear)
    (ade_dsdetach dwgid)
    (command "ZOOM" "e" "")
    (command "SAVEAS"
     "2000"
     nts_sheet        "\\"
     nts_sheet        ntsnum
     ".dwg"
; now clear everything out of the drawing
    (setq ss1 (ssget "X"))
    (command "ERASE" ss1 "")
    (setq ss1 nil)
  (setvar "cmddia" 1)
viva
« Reply #10 on: October 31, 2006, 12:37:15 AM »
Thanks for ur valuable information. I had learned so many news commands from ur discussion. It helped me a lot.
Regards
viva
