Author Topic: Sandcastle  (Read 2516 times)
Sandcastle
« on: October 27, 2006, 08:28:48 PM »
May be interesting for some ...
Overview
Sandcastle produces accurate, MSDN style, comprehensive documentation by reflecting over the source assemblies and optionally integrating XML Documentation Comments. Sandcastle has the following key features:
Works with or without authored comments
Supports Generics and .NET Framework 2.0
Sandcastle has 2 main components (MrefBuilder and Build Assembler)
MrefBuilder generates reflection xml file for Build Assembler
Build Assembler includes syntax generation, transformation..etc
Sandcastle is used internally to build .Net Framework documentation
http://www.microsoft.com/downloads/details.aspx?familyid=E82EA71D-DA89-42EE-A715-696E3A4873B2&displaylang=en
Create CHM or HxS build using Sandcastle
https://blogs.msdn.com/sandcastle/archive/2006/07/29/682398.aspx
It's Alive!
  • Retired
  • AKA Daniel
Re: Sandcastle
« Reply #1 on: October 28, 2006, 11:32:36 PM »
This is cool stuff for documenting your apps. It’s a little time consuming to make the detailed comments, but its well worth it in the long run. I found a version of NDoc that works really well with .NET 2.0 , I’ll switch to Sandcastle once it has a GUI
 http://www.kynosarges.de/NDoc.html
