Author Topic: Support File Search Path  (Read 7383 times)
deegeecees
Re: Support File Search Path
« Reply #15 on: October 25, 2006, 01:34:47 PM »
Oooooops, too slooooowwww....
Matersammichman
« Reply #16 on: October 25, 2006, 01:36:18 PM »
Yes, it saves "Support paths", but NOT "WORKING file support paths". They appear to be linked into the Support Paths, but non-editable directly.
David Hall
  • Automatic Duh Generator
« Reply #17 on: October 25, 2006, 01:36:44 PM »
nah, I just copy paste faster than you.  BTW, did you get yous working?
David Hall
« Reply #18 on: October 25, 2006, 01:37:30 PM »
Working paths are what you get after you hit apply and Acad resolves whether you put in valid paths
Matersammichman
« Reply #19 on: October 25, 2006, 01:40:01 PM »
Correct.
Unfortunately, when I deleted\overwrote the "Support" paths, it did not update the "Working" paths.
deegeecees
« Reply #20 on: October 25, 2006, 01:42:38 PM »
"Swamped" at the moment. Barely have time to type this. Its on the back burner for now. Just not enough time in the day some times, lunchtime is the only time I have to myself.
Matersammichman
« Reply #21 on: October 25, 2006, 02:10:25 PM »
'''Thanks guys, I was using that code to start with yesterday, but there's still a problem. Here is the exact code I am using:
Dim supppath3 As String
    supppath3 =
UCase(ThisDrawing.Application.Preferences.Files.SupportPath)
    If Not (InStr(1, supppath3, "G:\Arc\CAD System\Template") > 1) Then
        ThisDrawing.Application.Preferences.Files.SupportPath =
supppath3 & ";" & "G:\Arc\CAD System\Template"
    End If
    Exit Sub
'''what happens is that it will put it in the Support path once as UCase, and once as LCase. Why???
« Reply #22 on: October 25, 2006, 02:27:01 PM »
Duplications due to case and slash characters is why I have entries like this in my lisp library --
(defun _Replace ( oldText newText text / i )
    (if (/= oldText newText)
        (while (setq i (vl-string-search oldText text))
            (setq text
                (vl-string-subst
                    newText
                    oldText
                    text
                    i
    text
And then this --
(defun _AddStr ( str1 str2 delim )
    ;;  add str2 to the end of str1 if str2 doesn't exist in str1 (case
    ;;  and slash insensitive) -- put delim between str1 and str2
    (   (lambda ( string pattern )
                (null
                    (or
                        (wcmatch string pattern)
                        (wcmatch string (strcat pattern delim "*"))
                        (wcmatch string (strcat "*" delim pattern delim "*"))
                        (wcmatch string (strcat "*" delim pattern))
                (strcat str1 delim str2)
                str1
        (strcase (_Replace "/" "\\" str2))
        (strcase (_Replace "/" "\\" str1))
Feel free to convert to equivalent VB code. I'd do it but (1) headache (2) too sleepy, even though it's admittedly a trivial task.
David Hall
« Reply #23 on: October 25, 2006, 02:33:20 PM »
It is put in in lower case the first time, then the second time through, It converts it to upper case, and when the check is run to see if its there, it doesn't find it (I know its there, but upper and lower are treated as different cases)
The way to fix your problem is when you add the path, use all upper case
  supppath3 =
supppath3 & ";" & "G:\ARC\CAD SYSTEM\TEMPLATE"  ' ADDED THIS LINE
« Last Edit: October 25, 2006, 02:35:34 PM by CmdrDuh »
Matersammichman
« Reply #24 on: October 25, 2006, 02:33:51 PM »
Actually, I really appreciate all the help.
I just resolved my own dilemma. WooHoo!!!
Here's the deal:
For whatever reason, vba writes into the Support paths (and all the others as well) all in CAPS. If your code is written in anything else (mixed, or lower case), you will get two entries in your paths: One in whatever case your code is written in, and one in all caps.
David Hall
« Reply #25 on: October 25, 2006, 02:34:55 PM »
See my above post
Matersammichman
« Reply #26 on: October 25, 2006, 02:36:10 PM »
I think we were typing at the same time.
Thanks again swampers!
