Author Topic: Civil 3D - Mini Tutorials On Line  (Read 47848 times)
DinØsaur
  • Certified Bovine Scat Distributor...I lay it on THICK
  • But I don't WANT a Day Job
« on: October 19, 2006, 10:46:44 PM »
Member Michael Farrell has posted the first in a series of mini lessons for Civil 3D.  The first AVI addresses the basics of navigating through the unique Toolspace interface lasts around 20 minutes.  It can be downloaded at:
http://primeservicesglobal.com/tutorials.php
fixed link in post MST
appears the link broke again ... should work again
« Last Edit: August 06, 2015, 09:20:31 AM by DinØsaur »
Stephen R. Sherrill,
The DinØsaur
Civil 3D Specialist Emeritus
YAY ME !!!  I made it out alive !
DinØsaur
Re: Civil 3D - Mini Tutorials On Line
« Reply #1 on: October 26, 2006, 09:36:44 PM »
A second presentation is now available that covers tiips for setting up a template and migration from Land Desktop
The DinØsaur
« Reply #2 on: October 26, 2006, 10:21:30 PM »
Coming Soon POINTS!
Can't wait for that one. Thanks Mr. Farrell. :-)
thanks for the links Steve, I'll download it in the morning.
dgreble
« Reply #3 on: October 27, 2006, 09:35:17 AM »
Thanks for the heads up Dino! :-D
DinØsaur
« Reply #4 on: August 08, 2007, 12:34:48 PM »
BIG OL' BUMP
Michael has added a new tutorial to his list and has made significant improvement in the audio quality.  This new file is a 30 minute presentation on creating an existing surface with Civil 3D
The DinØsaur
« Reply #5 on: August 13, 2007, 01:44:03 PM »
DinØ,
Look a little closer and you will see a session covering the basics of MAP Drawing Cleanup operation as well.
jonesy
  • SuperMod
« Reply #6 on: August 17, 2007, 04:35:12 AM »
Bookmarked for the MAP cleanup. I'll look at that when I get back to work on Monday
Thanks Michael
dfarris75
« Reply #7 on: August 28, 2007, 03:31:46 PM »
Just got around to downloading the surface tutorial. The sound is indeed much improved, but the narration seems to be about 10-15 secs ahead of the video. :lol:
The file size is tremendously large as well. I wonder if there's a way to whittle that down any...
I also just noticed that the link for the Map Cleanup tutorial is pointing to the Migration video. You might want to smack around your webmaster a little.
« Last Edit: August 28, 2007, 03:35:08 PM by dfarris75 »
« Reply #8 on: May 15, 2008, 12:43:17 PM »
Well, file sizes are still a little large, however the audio seems be more synced up. Still trying to figure out where that delay came from? I didn't think it took that long for sound to go through the DA converter.
And a hearty thanks to Darcy for the shiny new wrapper!
« Last Edit: May 15, 2008, 12:56:57 PM by mjfarrell »
dfarris75
« Reply #9 on: May 27, 2008, 12:56:37 PM »
Hey no problem. You are more than welcome. I notice the xhtml code isn't checking out now. Did you change something? We might have to look at fixing that or just removing the code checkers.
« Reply #10 on: May 27, 2008, 12:59:06 PM »
I edited the data to add new links? Perhaps you might review the source code and advise, as to if it was ME or the Page Breeze editor responsible?
« Reply #11 on: June 06, 2008, 10:25:58 AM »
 :roll:
so did I break it?
dfarris75
« Reply #12 on: June 06, 2008, 11:03:56 AM »
If you click the xhtml button it will "qc" the page and tell you what's wrong. :wink:
« Reply #13 on: June 06, 2008, 11:08:09 AM »
And then...I will know how to fix it too, right? :lol:
dfarris75
« Reply #14 on: June 06, 2008, 11:45:54 AM »
I would think that an intellectual such as yourself would be able to yes. :whistle:
