Author Topic: How would one get the Vertex Object?  (Read 3376 times)
« on: October 19, 2006, 01:56:38 PM »
I mean how can one step through an AcDb2dPolyline to get the vertex objects?  I know you can do it with enames and entnext, but is there way way with straight ActiveX controls?  Question just popped into my head, and I didn't have/find an answer.
Thanks.
Re: How would one get the Vertex Object?
« Reply #1 on: October 19, 2006, 02:20:49 PM »
Mnimal / brute force / concept code --
(defun foo ( document 2dPlineObject / result )
        (lambda ( objectID )
            (while
                (eq "AcDb2dVertex"
                    (vla-get-objectname
                        (setq object
                            (vla-objectidtoobject
                                document
                                objectID
                (setq
                    result   (cons object result)
                    objectID (+ 8 objectID)
        (+ 8 (vla-get-objectID 2dPlineObject))
    (reverse result)
« Reply #2 on: October 19, 2006, 02:22:31 PM »
<not compatible with object dbx because of the vla-objectidtoobject call which works strictly in an active document context>
« Reply #3 on: October 19, 2006, 02:29:21 PM »
Is the the same way 'entnext' works?  Finds the code (hex?) of the object, and then adds one (8 because of hex number system) number to it?  Very interesting.  I would never have thought of doing it this way.
« Reply #4 on: October 19, 2006, 02:33:13 PM »
Kinda, insomuch as they are sequential entiies / objects.
No, nothing to do with hex. Just my observataion that ObjectIDs are issued as a multiple of 8.
Caution -- not tried against polylines with modified / deleted vertices -- driver beware.
« Reply #5 on: October 19, 2006, 02:37:48 PM »
Thanks again Michael.  I think this must be the only way.  I was hoping there was something simple I missed, like (vlax-invoke BlkObj 'GetAttributes), but for polylines.
« Reply #6 on: October 19, 2006, 02:39:36 PM »
My pleasure. I think it more of a demonstration of the <cough> complete object model Autodesk authored.
