Author Topic: Copy Layer State form Vport to Vport  (Read 8008 times)
Amsterdammed
  • Revit MEP 2016 Acad2013, OPEN DCL
« on: October 18, 2006, 10:29:41 AM »
Hello there,
I know i saw somewhere a lisp that copies the layer state from one VP to another. Anybody aware of that lisp?
Thanks in Advance
Bernd
Bernd
Diněsaur
  • Certified Bovine Scat Distributor...I lay it on THICK
  • But I don't WANT a Day Job
Re: Copy Layer State form Vport to Vport
« Reply #1 on: October 18, 2006, 10:49:56 AM »
I just use the "match properties" button after I get one viewport the way I want it.
Stephen R. Sherrill,
The Diněsaur
Civil 3D Specialist Emeritus
YAY ME !!!  I made it out alive !
« Reply #2 on: October 18, 2006, 11:13:24 AM »
You could get a list of the layer names from one viewport through code, but you would have to use the command 'vplayer' to freeze them in the one you are matching to.  You can't use 'entmod' on a viewport.
Side note:  You might be able to do it with ActiveX controls, haven't tried yet, but you can change some items with ActiveX, so this might be one.  Just throwing that out there.
But if this works, no need for code.
Didge
« Reply #3 on: October 18, 2006, 11:37:18 AM »
Cheers for that one Dinosaur, I never realised that match properties worked with viewport layers
(DOH!! - Slaps Head)
Think Slow......
« Reply #4 on: October 18, 2006, 11:42:33 AM »
« Last Edit: October 18, 2006, 11:51:11 AM by CAB »
I've reached the age where the happy hour is a nap. (░┐░)
Diněsaur
« Reply #5 on: October 18, 2006, 12:06:10 PM »
What if the vp is in another layout? :evil:
I have gone so far as to copy a viewport from one layout tab to a second one, match the properties and erase the copy to avoid messing with layer states.  I never have become comfortable with them.
When I am first setting up my sheets, I will get the viewport layers the way I want on each type of layout tab and then copy the entire tab for new sheets and adjust the views as necessary.
The Diněsaur
« Reply #6 on: October 18, 2006, 01:02:31 PM »
It doesn't make sense that you can match properties between open drawings but not between tabs in a single drawing.... :ugly:
Windows 10 x64 - AutoCAD /C3D 2020
Krushert
  • FREE BEER Tomorrow!!
« Reply #7 on: October 18, 2006, 01:14:48 PM »
I have always scratch my head over that one.
Diněsaur
« Reply #8 on: October 18, 2006, 04:10:35 PM »
I just tried this or the first time using 2007.  It still works at least as long as you want to keep the same scale in each viewport.  It will NOT however save the layer settings when copying a viewport between tabs as it would with 2006 - bummer . . . that was a good trick.
The Diněsaur
Amsterdammed
« Reply #9 on: October 20, 2006, 11:44:19 AM »
I'm working with Acad 2002, Match Prop doesn't work on Vports there.
Bernd
Bernd
Crank
« Reply #10 on: October 20, 2006, 03:06:16 PM »
For Acad2002 you can use the attached routine.
Vault Professional 2018     +     AEC Collection
