Author Topic: One Of The Strangest Things I've Ever Seen...  (Read 11002 times)
deegeecees
Re: One Of The Strangest Things I've Ever Seen...
« Reply #45 on: October 23, 2006, 12:26:24 PM »
Voluptuous Blonde Aquaintance
Maverick®
« Reply #46 on: October 23, 2006, 12:31:36 PM »
 :lmao: :lmao: :lmao:
MikeJarosz
« Reply #47 on: October 26, 2006, 05:30:10 PM »
Sorry to break into your little group here but.....
When a command like BLOCK disappears completely, try it with a leading period, say .BLOCK This is different from the the minus sign, which uses the release 13 version of the command.
There is a command UNDEFINE that makes a command disappear, but REDEFINE brings it back. It's a favorite dirty trick of mine. It's in the ACAD help file.  :-)
sinc
« Reply #48 on: October 26, 2006, 07:32:09 PM »
It's not an R13 version of the command, it's just a command-line version of the command.  The hyphen merely suppresses the dialog box.  For some commands (such as PURGE), this gives you options that aren't available in the dialog box.
« Reply #49 on: October 26, 2006, 09:35:03 PM »
Another simple fix for this issue is to export to R14 dxf, then close the drawing. Upon opening the dxf and saving as DWG all should be right with the world.
