Author Topic: One Of The Strangest Things I've Ever Seen...  (Read 10997 times)
deegeecees
Re: One Of The Strangest Things I've Ever Seen...
« Reply #30 on: October 17, 2006, 03:39:15 PM »
Beers for me too.
deegeecees
« Reply #31 on: October 17, 2006, 03:48:38 PM »
This is the fix:
Started a new drawing, inserted suspect drawing @0,0, xploded, and voila!
All is well.
« Reply #32 on: October 17, 2006, 05:07:32 PM »
This is the fix:
Well, that may have worked for that drawing, but what about a drawing that has more than just things in ModelSpace?
Using Insert only brings in Modelspace.....Using the TrueConvert tool you can save the file as a  2007 file then resave as a 2000 format file and it should also fix the problem, but leave any Paperspace items/tabs intact.
For the next time.....:-)
deegeecees
« Reply #33 on: October 17, 2006, 05:40:06 PM »
I apologize for not being thorough. Been doing the Headless Chicken Dance here alot. We only have 2002, so thats (unfortunately) not an option. We intercepted this file from one of our clients, so we would have to send it back and show the client how to do this, or redraw the Pspace objects.
« Reply #34 on: October 17, 2006, 05:50:51 PM »
Yes, it is, an option. You do not have to have ANY version of AutoCad installed to use TrueConvert.....it is a standalone program.
Check it out!
HTH
deegeecees
« Reply #35 on: October 17, 2006, 06:02:11 PM »
If its not a free app, then I don't think it would be an option. MIS has my dept handicapped, bound gagged, and hogtied. Getting an application with such a limited use would never get through.
« Reply #36 on: October 17, 2006, 06:14:07 PM »
Quote from: DWG TrueConvert Website
DWG TrueConvert™
This FREE* download translates any AutoCAD or AutoCAD-based drawing file for compatibility with AutoCAD Release 14 through AutoCAD 2007.
*FREE products subject to the terms and conditions of the end-user license agreement that accompanies download of the software.
IOW, it's free.... ;-)
deegeecees
« Reply #37 on: October 17, 2006, 06:22:53 PM »
Yeah!
hyposmurf
« Reply #38 on: October 23, 2006, 08:10:06 AM »
Strangest thing Ive seen in a CAD drawing was two layers named exactly the same. :?
Maverick®
« Reply #39 on: October 23, 2006, 08:50:53 AM »
That's nothin'
I had one that when I opened it a voice came out saying "Yeah the coffee tastes like carp but you need it".
I think it might have had a virus embedded because now I hear it every morning.  :|
Murphy
« Reply #40 on: October 23, 2006, 09:26:32 AM »
Mav,
That's one of the new voices in your head.
Drawings can't talk.
Maverick®
« Reply #41 on: October 23, 2006, 09:43:16 AM »
*Spicoli*   "Chaaaa"
Just wait until you get one.
*Walks off muttering "stick to the plan..."*
deegeecees
« Reply #42 on: October 23, 2006, 11:43:37 AM »
That's nothin'
Could be triggered from an application event in VBA.
daron
« Reply #43 on: October 23, 2006, 12:18:10 PM »
As for the items in paperspace? If and only if you've taken the pains to rename each tab, you can use design center to drag and drop each tab from the corrupt file into the new one and voila, your drawing is back in business
Maverick®
« Reply #44 on: October 23, 2006, 12:20:46 PM »
  Volume of Beverage Aquired?
  Very Bad A.M.?
  Vicious Bed Astrangement?
